spidfer said:Im fine here - 12k in 3DMark03, and it chews through any game in 1280x1024
http://service.futuremark.com/compare?2k3=2897531
LMAO, sorry just find it funny how many times people said to install the mobo drivers, but glad you got full use of your card now, its so baller I love mineRof_lmao said:i did some snooping with ,my ccard... ran aquamark 3 and only partial amounts of my video card's memory was there.... that seemed odd..... so i read somewhere i need to install my mobo manufact's agp gart drivers.... i did and my performance has almost tripled...
My aopen ak86-l let me install each driver individually, everytime i tried the 4in1 driver it never installed anything.Strategy said:Ive installed the VIA 4in1's (I hate VIA), does this chipsit have a gart driver? or is it built in with the 4in1's? Im really thinking of getting an nforce3 board just to get this card working right.
Did you try installing the drivers individually? Because I had shitty performance after i tried the 4in1 driver and nothing seemed to work right. Installed each driver individually and it worked like a charm.Strategy said:Its not heat though, my temps are fine. Im thinking its a bad card, but comp usa is sold out of them so I cant really take it back and get another one.
I need to know how that guy a couple posts back noticed his ram wasnt all there or something.
DiNkMe said:Did you try installing the drivers individually? Because I had shitty performance after i tried the 4in1 driver and nothing seemed to work right. Installed each driver individually and it worked like a charm.
Sorry about this post I was a lil high earlier and not sure why i thought that either way the 4in1 driver didnt work for me for the USB2 and gigabit lan, but as i look now it doesnt have chipset drivers that are individual, my badDiNkMe said:Did you try installing the drivers individually? Because I had shitty performance after i tried the 4in1 driver and nothing seemed to work right. Installed each driver individually and it worked like a charm.
wilson502 said:just installed updated chipset drivers, see what this does, oh btw does the application accelrator help? My PSU isnt sweating with this new video card, the voltages have stayed exactly the same, my idle temp for my 6800gt is about 58C, and im at ultra speeds.
Strategy said:Maybe its this power supply?
So far 3 of us here that are having issues are using the Antec Truepower 430W PSU.
Strategy said:New powersupply did nothing.
Rof_lmao said:anyoen got a gig of decent ram (3200 or more) cause im poor now... Wait, does fastwrites damage the performance when its on?
Barnaby said:to me it sounds like the GART driver got corrupted. I know someone mentioned resintalling in on his system fixed it, what about everyone else?
I'd recommend downloading the latest chipset drivers for your mobo, and instead of running it, extract it with winrar or something. then go into device manager, and under the system resources sections, open up the pci to agp bridge controller, and update the driver from there. Point it to the correct folder, that way you know windows is installing it.
If you uninstall video card drivers, and use driver cleaner, alot of time it will uninstall the GART driver as well. Especially when going from ATI to nVidia or vice versa..
other than that, think it's time to try that card in someone else's machine to see if it's a hardware issue..
