theelviscerator said:according to the scribes its all user error.......def sounds like mobo chipset issues.
Thats what I was thinking, but people with VIA, INTEL and other chipsets are having the same problems....
rayg said:your processor is too slow, multiplayer games like joint ops and ut2k4 are extremely cpu dependent, you could put AA/AF on and youd still get the same fps most likely
jon_k said:I would reset you bios to all defaults, then make sure fast writes are off. Then I would turn off the OC on your GPU and CPU. You never know, OCs can do some wierd things sometime. Then I would 100% NTFS Full format your HD. Install the latest windows updates, chipset drivers, video cards drivers, and sound card drivers. If that dosent' fix it, you have a hardware problem.
lopoetve said:Ok. Lets try this:
Take everything back to stock speeds. Drop the overclocks, dropt the voltage increases. STOCK speeds.
Then try. Report back.
I have a hunch,
Dagoth said:my system is a similar Spec:
AMD Athlon 64 3200 (Socket 754)
Asus K8VSE Deluxe (Socket 754) Motherboard
Corsair 1GB DDR XMS3200LL Pro TwinX (2x512MB)
XFX 6800GT 350/1.0
Samsung Spinpoint 160gb SATA RAID 0
380w Antec PSU
in UT2K4 I get on average 60-70fps @ 1280x1024 2x/8X
Farcry and Doom run really well at high settings (farcry using SM3.0)
my 3d mark 03 was 10,000+ (using 61.21 drivers & DX9.0b)
I'm currently using 61.77 drivers and DirectX 9.0c Windows SP1
so you should be looking at similar scores...
ThunderGod66 said:Something is definitely up...with both the cpu and vid card overclocked, these are my 3dmark scores:
3DMark 2001 = 16661
3DMark 2003 = 11244
I mean if my 3DMark 2003 score is 11244...my 2001 score should definitely be a lot higher than it is.
By the way, I'm using an MSI KT3 Ultra2 motherboard.
wilson502 said:hmm my ut2k4 at 1280x1024 maxed out runs in onslaught in the 30-50 fps range. Something feels like its holding it back. I just defragged my hard drive which was heavily fragmented.
lopoetve said:RAM + cpu.
Strategy said:I dont think so because mine is getting almost the same performance as his. Its like something isnt working right together.
TheRapture said:For a 2.4B P4, your 3DM01 scores are actually right on. 2001 is cpu limited with the newer cards, with my XP running 2380mhz I only get mid 17k's in 2001. 3DM03 I get 11600's+....really, you are right on in those benches.
wilson502 said:joint ops is horribly unoptmized im thinking or need a REALLY fast cpu like an amd 3800+ o/ced to 4000+ speeds or something.
