sparky3009
- Jan 5, 2006
Haven't built a computer in a while, and i sold my last desktop over the summer so I haven't really been paying attention to the whole hardware thing. Last news I hard, Phenom was having a hard time getting off, and was getting a lot of negative feedback for the forums. I guess AMD was having some problems getting the 65nm proc's released. Anyways I'm wanting to build a new computer used mainly for research, a small amount of WoW, and just a little farting around with networking. (running it as a gateway, stuff like that)
Anyways, I don't need all the components... Just mobo, proc, ram, hdd, maybe a psu, and a few misc parts (fans).
Requirements:
Affordable (#1 bottleneck, as usual)
Minimum 1Gig ram
Want onboard video for now, and at least 1 pcie slot for expansion later (dont want to budget in a vid card)
Don't want anything thats already obsolete (no 939 pin proc/mobo's)
I want it to last me a good 2 years with relatively minimal upgrades (no mobo swaps), and I think 2x2gig max mem will last until then, even though I'm not getting that much now.
Here's what I came up with....
AMD Athlon 64 X2 7750 2.7GHz Socket AM2+ 95W Dual-Core black edition Processor - Retail New arrival, Athlon 2.7GHz Black Edition
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103300
ASUS M2N68-AM AM2+/AM2 NVIDIA GeForce 7050PV Micro ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131342
Kingston HyperX 1GB 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104012
Seagate Barracuda 7200.10 ST3160815AS 160GB 7200 RPM 8MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148230
OCZ ModXStream Pro OCZ400MXSP 400W ATX12V V2.2 Modular Active PFC Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341015
Grand total for that is $263.22
I was also looking at Intel proc/mobo's but couldn't find a processor that was relatively top-end in terms of performance that also met the 'under $100' thing I'm aiming for.
I found a mobo I'd rather use than the amd one above, but idk what I want for a processor then.....
XFX MG-63MI-7109 Motherboard - NVIDIA nForce 630i/7100, Socket 775, MicroATX, Audio, Video, HDMI, PCI Express, Gigabit LAN, S/PDIF, USB 2.0, SATA, RAID, DVI Support
http://www.tigerdirect.com/applicat...?EdpNo=3517183&csid=ITD&body=MAIN#detailspecs
Anybody have any suggestions? Definitely not looking to go over $350, would LIKE to keep it under $300 but I guess I don't have to. I always set my price range and spend $50+ more than I budgeted for so I'll probably spend $400-$500, but you didn't hear me say that! :-O
Requirements:
Minimum 1Gig ram
