M76
- Jun 12, 2012
Sorry, but changing what you call it doesn't magically make it logical. That's fallacy 101 stuff that only someone with a brain that's been DISEASED by years of inverted use would think is ok.
Rotate the screen 90 degrees and rotate your mouse 90 degrees. It doesn't work anymore because it's inconsistent and illogical.
- Not understanding the concept does not make it illogical.
- There is no fallacy 101, you are conflating things.
Because in your head you are not controlling the viewer, you are controlling the target, which is actually illogical. When you aim your gun or camera in real life you are not controlling the target, you are controlling the observer. Pitch back, or pitch forward.It's very simple. Imagine placing your mouse on your screen. Your camera looks where you move your mouse. You can even actually place your mouse on your screen and see it in real life if playing inverted has compeltely ruined your ability to imagine things.
For example when you are leaping off an edge you are pitching forward, therefore forward = down.
