My machine requires no bling.
Just the led's on my ram sticks here... Otherwise no lights.
QFT. My case has no window, and no lighting. I also leave the power & HDD LEDs unplugged. Just a quiet, unassuming black box.
I make sure all my standard LEDs are plugged in, but mainly for diagnostic purposes. I also feel that connecting those is simply part of building the machine correctly. Some of my friends build machines with those types of shortcuts taken and that just bothers me.
I plug them in until the machine is up and running 100% stable, or when I do a OS reinstall. After that I unplug them again. I really hate the flashing of the hard drive light. It drives me nuts. I could keep the power one plugged in, but it does make just enough noise that I can tell when its running.
The hard drive light bugs me so much, that all of my laptops have a piece of electrical tape over the LEDs. I miss the "black out" key on my old Gateway. When you pressed it it turned off all of the lights.
LED 120mm case fan, one LED light cluster aimed at the transparent fan on the video card closest to the case window, a Zalman 7000-b heat sink fan with LEDs, Razer Copperhead mouse, Saitek Eclipse keyboard, blue LED back lit display for thermal probes built into the case and another blue LED back lit display showing PSU temp w/ rheostat. (bad camera phone pic)
I didn't think it looked like a real Eclipse either (they usually have the really distinctive corner "feet"). It looks a bit more like this keyboard if you ask me.That doesn't look like the Eclipse at all, first- or second-gen. I'm not calling you out, just curious. Am I crazy?
good catch, thats an old pic with the sunbeam solar.
I could take pics of the new monitor / keyboard if it makes you happy =P
