Looking good. Can't wait for more updates. I normally follow your guides on ocn but it makes it way easier here.
Thanks!
Care to explain the flow in your GPUs? aestetically it looks great, but the logic in my said "whoa back TF up, that isnt right!"
Still looking great
I'll explain below
I believe it's called parallel flow, and it works fine.
Yup
Ok I understand it now. I was confused as well, right up until I looked at it again. Each card has an A & B port. For the sack of simplicity A is on the left B on the right. I'm going to assume the pumps are in the bottom and so the water comes into A on the bottom card. Some of the water flows through the card and out B. The rest of the flows out the top of A and into the A on the top card and through to B. The water from the bottom card flow through B on the top card rejoining with the other water and continues through the loop.
Now hopefully that made sense and I didn't confuse you anymore than you were.
Yeah you are pretty much right. It is called parallel flow. It means both cards get 'fresh' water from the radiator rather than card A getting the 'cold' water and card B getting 'warm' water from the first card. This ONLY works if both blocks are the same i.e. the same graphics card with the same blocks. What happens is the water is split evenly because the pressure and flow is the same throughout - the two routes the water can take are both the same length and 'volume'. This pic might help:
Update #25 - 16/08/2010
I needed some monies for this project so I have been doing a sleeving job for someone. Should pay for one and a half of my 4 hard drives that i need to buy! This is a Corsair HX1000 sleeved with red and black MDPC sleeving. PSU is modded quite a bit - cut off the non-modular 6+2pin cables and made them modular. Replaced all the plugs and pins with MDPC ones instead of the silly corsair ones. It isn't done yet but should be finished soon.
Here is a load of stuff that arrived.
This is an audio DAC that i ordered from Taiwan. I will be making a small white acrylic cube to house it in.
I ordered this because i was getting major interference from my 5850's when they were stressing out whilst gaming - they were causing loads of noise on my audio from the PC. Optical out should eliminate this.
3 parts to it - transformer, power board, and the DAC itself.
I also got a load of electronics stuff from Rapid. These are some resistors i ordered, they are huuuge! Reason they are so large is because they are high power ones - take up to 2 watts. These are for my LEDs.
Also got some black connectors for my new sleeving idea.
I wasn't happy with my GPU connector solution - as a few people said, it looked very bulky. People said i should get some Bitspower Crystal links, but i don't like the idea that they aren't entirely 'secure'.
My solution was to buy these tiny matt black compressions with clear tubing - these are 10mm OD, 8mm ID!
On the left is a 3/4" OD, 1/2" ID fitting with matching white tubing.
These are some 3mm white LEDs
This is what they will look like in the drive bay covers. I will hook them up to the FC5 to control the brightness.
Something to look forward to - another package arrived from MDPC-X with this awesome drawing from Nils
