- Oct 22, 2004
Is there any reason this doesn't work?
If you are browsing the forums when you receive a new private message, the system can pop-up a notification box informing you of the new message.
Show New Private Message Notification Pop-up
There's a check box to enable/disable this, and it used to work once upon a time, but it no longer works.
I really find it helpful for seeing when I get PMs. And if it was removed for some reason, well, you can simply uncheck it...
