Plugged in, Not charging (W7)
Discussion in 'Operating Systems' started by mobusta1, Dec 1, 2009.
  1. mobusta1
    mobusta1 2[H]4U
    2,659
    May 1, 2008
    I use to have this problem all the time where I would plug in the power to my laptop and it woulnd't charge. If you hovered over to the battery it would just say plugged in, not charging. Now I'm seeing this again in W7. Anyone find a fix for this or a work around?
  2. DeaconFrost
    DeaconFrost [H]ardForum Junkie
    10,861
    Sep 6, 2007
    I just saw this on my sister-in-law's laptop. The solution was to get a new power adapter, because it wasn't supplying enough voltage.
  3. Menelmarar
    Menelmarar [H]ardness Supreme
    5,483
    Feb 15, 2001
    Win7 is irrelevant to your problem.
    DeaconFrost probably nailed it. Power brick getting flaky, or maybe a lose connection in it's cables.
  4. heatlesssun
    heatlesssun Pick your own.....you deserve it.
    46,997
    Nov 5, 2005
    I'm having the same problem with an older tablet of mine but I think that its the battery as I've tried a couple of power adapters that work fine on other machines.
    I don't think that its the OS. Try turning off your machine, reboot and see if charging resumes.
  5. DeaconFrost
    10,861
    Sep 6, 2007
    That's how I figured it out. I rebooted into the BIOS to see if it would register as charging. Dell's also have some nice diagnostics, that told me it was the adapter, and not the battery.
  6. mobusta1
    mobusta1 2[H]4U
    2,659
    May 1, 2008
    It's a brand new laptop..
  7. DeaconFrost
    10,861
    Sep 6, 2007
    That doesn't mean the battery or adapter can't have an issue. The good news is, it should still be under warranty, so a replacement would be free.
  8. Azhar
    Azhar Fixing stupid since 1972
    19,501
    Jan 9, 2001
    I deal with about 20 new laptops a month. Believe me, there hardly comes a shipment without a faulty laptop or three.
    I've had numerous problems as you described. It's either the adapter or battery. I tend to purchase the same laptop by the bulk, so I'm always able to test either the battery or adapter on another perfectly working laptop to determine which is faulty.
    Laptops are unfortunately fragile in shipment. You should see how they handle your boxes in the warehouse and on flight.
