Please Suggest PCI Riser
redstars
I believe I am looking for a PCI riser for my ASUS M2N32-SLI Deluxe motherboard. As many of you are probably well aware one PCI slot becomes blocked by a graphics card when ran in SLI mode. I am looking for a solution to recover this slot for use with a tape drive controller I have. Is a PCI riser card even what I should be looking for?
Thanks for any help. :confused:
I haven't seen a way to use a blocked slot like that. I haven't seen a riser or anything like a riser that would allow you to use the slot either. One of the downsides to SLI I suppose.
I've seen them before on older OEM computers, but I just don't know how you'd rig it up without blocking more slots so the right angle risers are out. Theoretically, since you're only looking at using a controller card that doesn't need to be mounted in a regular slot since you don't need access to it, you might be able to rig up your own mounting inside your case with one of the flexible extenders.
http://www.adexelec.com/pci32.htm#PCIRX4-FLEX
Not ideal, but it would probably work if you can keep it from shorting out.
Thanks kirbyrj,
That is essentially what I was planning. I'll basically be putting this in a full size server chassis with plenty of room. The tape drive and controller will be connected internally, so hypothetically I believe I can fabricate something to mount the controller in the case.
I just don't know how long the extender cables are. That's probably the only thing I'd look into. Good luck :).
