Please Review My Upgrade Build
Sir Crazy
Current Machine:
Mainboard: MSI MS-6577
Chipset: Intel i845GE
Processor: Intel Pentium 4 @ 2400MHz
RAM: 1024MB (2 X 512 DDR-SDRAM)
Video Card: Nvidia GeForce 6600
Hard Disk: ST380012A (80 GB)
HArd Disk: WDC (80 GB)
DVD-Rom Drive: Mad Dog MD-16XDVD9A4
CD-Rom Drive: SAMSUNG CD-R/RW SW-248F
Monitor: Westinghouse 19" LCM-19v7 LCD monitor 1280 x 1024 resolution 8 ms response time.
Power Supply: Dynex DX-PS500W 500-Watt ATX CPU Power Supply
Case: Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
OS: Win XP SP2 OEM
Want:
BFG Tech BFGR88640GTSOC2E GeForce 8800GTS 640MB $425.99
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX Intel Motherboard $109.99 [Only the features that I want]
Intel Core 2 Duo E6600 Conroe 2.4GHz 4M shared L2 Cache LGA 775 Processor $227.99 [Want to overclock to 3GHz]
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory $69.99 [good price]
Microsoft Windows Vista Home Premium DVD - Retail $219.99
Total: $1054
Other Info:
My current machine is not capabable of playing Oblivion except at the lowest settings. Even then it's still a slide show in combat. I would like to play Oblivion at a resolution of 1280 x 1024 at some of the highest settings. I plan to reuse the DVD-ROM drive, the WDC Hard drive, Monitor, Case, and Power Supply from my current machine. I hope to get 4-5 years of use out of new machine (with upgrades). I have never overclocked a machine before and I would like to give it a try. From the reviews I'v read on the E6600, overclocking the processer to 3GHz is "easy." I would like to find out if that is true.
My machine's main purpose is for gaming. I perfer RPGs, simulations, and strategy games. I have no probelms running games at lower settings so long as it does not distract from the gameplay.
Questions:
Do you beleive that (given the case I'm using) the stock heatsink will be enough to keep the processor cool?
Do you beleive there are any problems using my current power supply? It's less then a year old.
Do you forsee any problems with the hardware that I have choosen?
I would like to reduce the cost of the build if possible. Do you have any suggestions on how I can do this?
What thermal compound do you recomend?
Your upgrade parts list looks good, except for the processor. The E6600 is discontinued as has been replaced by the 3.0ghz E6850. However, the E6750 is a better buy, as both the E6850 and E6750 have the same OC headroom. Replace the E6600 with an E6750 if you want dual core, or consider the Q6600 if you want quad.
The stock fan should suffice for a decent OC, although there is little reason not to get a better air cooler if you can afford it (the best ones are around $50-$60.) Consider the Tuniq Tower or Thermalright Ultra Extreme for an easy 4ghz+ OC with the 6750 or 6850. Quads have less OC head room... The general high end for a G0 stepping (current build) Quad Q6000 is around 3.6ghz.
I'm by no means a PSU expert, so I can't say if your current unit is good, or if it'll hold up. I'll leave that question to someone else.
As for reducing the cost, you can easily do so by dropping down to an 8800 GTS 320. It's a good match for 1280x1024 with current games, and if you don't need to run future games at the highest of settings, you should be happy with it. Keep in mind that the latest RTS bombshell, World in Conflict, has been giving the top of the line GTXs cards a beating, so do some research to make sure the GTS 320 is a good solution before getting it over a GTS 640 or GTX.
As for the thermal compound, I'd just as soon recommend the tried and true Arctic Silver 5 before anything else.
Good luck,
Mark.
Questions:
1) It will keep it cool up to 2.8Ghz.
2) Yes... its Dynex. (I'm trying to find more info on it)
3) No
4) EASY... get the E6750 instead of the E6600. Get the 320MB instead of the 640MB. I took too long to post, so Mark beat me to it. I agree with him.
5) Arctic Cooling MX-2 or AS5
Get a Scythe Ninja Plus Rev.B or Tuniq tower to cool your OC'd CPU.
$35 - Scythe SCNJ-1100P Ninja Plus Rev.B 120mm CPU HSF
$45 - Tuniq Tower 120mm CPU HSF
FYI, my E6750 reaches 3.2Ghz on stock voltage with G.Skill NQ ram. I can OC the RAM to 430Mhz, resulting in a3.4Ghz OC. With Ballistix, it reaches 4Ghz. My board is the RAID version of the DS3L... the DS3R. My cooler is the Tuniq Tower and TIM is MX-2... keeps my CPU nice and cool.
$110 - Crucial Ballistix 2GB (2x1GB) DDR2-800 BL2KIT12864AA804 ($47MIR)
EDIT: found the manual for Dynex DX-PS500W. According to the manual, theres around 30A or so on the combined +12V rail. I've never heard of Dynex before, as far as PSUs go, so I'm not sure how trustworthy their advertising is. I also have no clue how good their quality is. Post the question at jonnyguru.com forums, or in the PSU subforum here.
500W is plenty of power for the system you propose... But I'm talking a quality power supply that will actually give you 500W.
Not some POS thing that dies at 250W.
Don't know where Dynex fits in
Personally, I'd spend $90 on a quality powersupply. Something like the Corsair 550. Doesn't have to be that one though. There are plenty of good powersupply's out there.
Will that Dynex work? Most likely, but I wouldn't trust it?
My general rule is, never use a generic power supply. You should buy the Corsair VX450, great power supply, plenty of power for your usage. Also, I would ditch the 8800GTS and now buy the ATi HD2900 Pro, it is a 2900XT, but underclocked, meaning that you could put it back up and get a more expensive card for less than the GTS. The CPU, of course, should be changed to something else, I would personally go for the E6750 for dual core, and the Q6600 G0 for quad core. I would go for the latter if you can afford it, but it isn't really that needed. Also, don't bother with the retail version of Vista, just buy the OEM instead, because, by the time that you upgrade your system, Vista will probably be replaced anyway (Microsoft WANT to release a new version of Windows by 2009, but that isn't really going to happen). Overall, you would have to upgrade Windows about 3 times with OEM's before equaling the price of the retail. That is three computers. In other words, about five years.
Thanks for your excellent replies.
I have made a few changes to the list of parts that I want. It costs me less then before but I think I'm far better off. The *** indicates the changes.
Want:
EVGA 320-P2-N811-AR GeForce 8800GTS 320MB 320-bit GDDR3 $289.99 ***
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX Intel Motherboard $109.99 [Only the Features that I want]
Intel Core 2 Duo E6750 Conroe 2.66GHz 4M shared L2 Cache LGA 775 Processor $192.99 [Want to overclock to 3GHz] ***
Microsoft Windows Vista 32-Bit Home Premium for System Builders Single Pack DVD - OEM $111.99 ***
CORSAIR CMPSU-520HX ATX12V v2.2 and EPS12V 2.91 520W Power Supply $129.99 ***
ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler $19.99 ***
Arctic Silver 5 Thermal Compound - OEM $5.99 ***
Total: $931
Please let me know if you see any problems.
Again thanks for your replies, they have been very helpful.
I will stick with what I said before, but I would ditch the 8800GTS for the 2900 Pro, which is faster, and cheaper, then get the Corsair VX450 power supply. If you wanted to, you could also consider buying the 64 bit version of Vista which runs fine, though it doesn't actually make any difference.
