Please Review i7 system build
a little off
Man it's been a while since I posted here, but I need a 2nd set of eyes to tell if I am screwing anything up.
This is what I am planning on picking up, and want to tide me over for a while...at least until they come out with dual PCIe 2.0 on a Dual Quad board...
1 - SUPERMICRO CSE-733TQ-645B Black Mid-Tower & Workstation Server Case
1 - ASUS P6T Deluxe LGA 1366 Intel X58 ATX Intel Motherboard
1 - Intel Core i7 940 Nehalem 2.93GHz LGA 1366 130W Quad-Core Processor
3 - G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Dual Channel Kit Desktop Memory Model
2 - BFG Tech BFGE88512GTSE GeForce 8800GTS (G92) 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
4 - Western Digital VelociRaptor WD1500HLFS 150GB 10000 RPM SATA 3.0Gb/s Hard Drive
2 - SAMSUNG 22X DVD Burner Black SATA Model SH-S223F - OEM
1 - COOLMAX CUG-700B 700W ATX12V v2.2 / EPS12V SLI Certified CrossFire Ready Modular Active PFC Power Supply
Currently running:
Asus PC-DL Deluxe
Dual Xeon 3.2Ghz
4 GB RAM
Dual 7200rpm drives
AGP Nvidia something or another....
Vista
Adobe Lightroom and VMWare should be the heaviest I think...Watching TV shows, MS Money, SSH, web, markup work..ohh and email...I love email. The only games I play on this come installed with Vista..nothing FPS, or anything like that...The Wii-Station-360 in the other room works just fine.
Don't really have one, but as you can tell I'm not buying from Alienware either...I want value for my money and a decent upgrade path if possible.
3) Where do you live?
32/Male/St. Louis and I love ponies!
4) What exact parts do you need for that budget? CPU, RAM, case, etc.
I'm not reusing anything from my currently system except external devices (KB, Mousem speakers and monitors).
Continued from above, I need the box and everything on the INSIDE, not reusing jack.
6) Will you be overclocking?
No
7) What size monitor do you have or plan to have?
2 - 22" 1650x1080 but will be up grading to 4 - 1920x1200 monitors down the road
Within the next 4-6 weeks...can wait if something really tasty is coming out in the very near future.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
The VelociRaptor's will be in RAID5 which the MB supports and I do NEED...and SLI would be nice if I can hang 4 monitors off it.
Ok lose that 8800 GT... since you are not gaming on the pc, I would suggest a 4670 in its place. Cosair 550 watt powersupply in place of that Coolmax PSU. Core i7 uses triple channel memory, 3 x 2 gig DDR3 1333 kit from g.skill or cosair and finally Raptors are waste of good money. WD 640 gigs are much better value.
I would get the i7 920 instead of the 940. It's not worth the extra money for the Mhz, IMHO. And I agree with It_shiro about the hard drives.
What Lt-shiro and Bisectors Fore said-
- Get a better quality PSU like the Corsair 550VX or 750TX and BFG LS-550 or ES-800.
- Drop the video card down to the HD4670 and lower
- Drop the i7 940 down to the i7 920 and lose only a few hundred Mhz.
What do you need Raid5 for? You do know that Raid5 has horrible write speed with onboard Raid controllers right?
Since you're not gaming, no need for SLI. You can use multiple video cads to power multiple monitors without using Crossfire or SLI.
I agree with Danny (who agrees with everyone else; therefore I agree with everyone else).
Seriously, ditch the raptors (lower the vidcard and get a much better PSU). They're only around 8% faster, at most, than the aforementioned WD640AAKS drives, yet they cost so much more.
The asl bit was hilarious, lol.
I know about the write speeds and was compensating with Raptors, it seemed cheaper then shelling out the cash for a RAID5 card (It seems that a couple of the 3ware RAID cards and the WD640 are about $50 cheaper then just the Raptors).
I use RAID5 for stability, I just upgraded to Vista after losing a 6-7 year old install of XP due to hardware failure...I test everything I install out in a VM for usability and stability before installing on my host. When I build this new system, I full expect it to be my last install for many years and like RAID5. Additionally, I do a bit of work with VM's and backing them up over USB, ESATA or the network really sucks. With this setup, I will actually buy a 5th disk just to have it ready for stand by and recovery.
About $450 in savings if you go with what I just listed. This is alot considering you can use this money for the monitors.
Hmm.. maybe an HD 4670 may not be a bad idea after all. The MSI Radeon HD 4670 has 2 x Dual Link DVI ports. Heh, just in case you happen to get a 30". Buy 2 of these instead of that 1 x 8800 GTS vieo card. with these 2 x Radeons in 2 of the PCI-E slots you can run multi monitors. The Radeon HD 4550 card I listed earlier you still can but, kinda ugly having VGA and DVI cables conected to each card. Make it all consistent with 4 x DVI cables total. 2 x DVI cables going to each card. Or you can even get 2 x Sapphire Radeon HD3650 512MB for $55/each w/free shipping. This outta do fine also.
