StealthGuardian
- Aug 3, 2008
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
My PC will be used for gaming, graphics design, coding, level design, video editing and so fourth. As far as gaming is concerned, my resolution will be no higher than 1650x1050 with all settings maxed. I just want to be able to play the latest games without compromising too much. I'm not interested in the best parts as much as I am with getting a good price to performance ratio.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$800 or less.
3. What country YOU will be buying YOUR parts from.
USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
No brand preference, just whatever is good at the moment.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
I plan on using these parts from my current build:
-19 inch ViewSonic VX922 LCD monitor
-keyboard + mouse
-Altec lansing sound system
-FSP Group (Fortron Source) Blue Storm 500W ATX12V V2.0 power supply
My current PC is an athlon 64 3200+ and while it has served me well for three years, it cant keep up with the newer games and applications.
6. IF YOU have searched and/or read similar threads.
I've read similar threads but everyone has different preferences.
7. IF YOU plan on overclocking or run the system at default speeds.
I plan on doing minor overclocking, nothing too major, and or run it at default speeds if it suits me.
8. WHEN do you plan to build it?
As soon as the parts arrive.
So without further ado, here are the parts:
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Quad-Core Processor - Retail:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
I've decided to make the jump to quad since I will be running many processor intensive applications as well as gaming. Besides, I guess it makes my system somewhat "future-proof", if that word exists in the computer building world nowadays.
ASUS P5Q LGA 775 Intel P45 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131295
This motherboard probably serves all my needs and more. If someone can recommend a cheaper brand then all the better.
SAPPHIRE 100243L Radeon HD 4870 512MB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102748
It was between this card and the 4850, tough choice but I want something that will last 1-2 years.
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
SAMSUNG Black 20X DVD+R 8X DVD+RW
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151154
Creative Sound Blaster SB0570 Audigy SE 7.1 Channels 24-bit 96KHz PCI Interface Sound Card - Retail
http://www.newegg.com/Product/...x?Item=N82E16829102002
The total is $866; a little more than my original budget but I won't be upgrading again in a long time. Some have suggested that my current PSU is a bit outdated and that the 4870 is far beyond my needs but I want input from you guys. If that is the case, then I can just go with the 4850 and opt for a better power supply:
4850
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121253
power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341002
Thanks in advance for the help.
$800 or less.
USA
-keyboard + mouse
4850
power supply
