palpatineli
- Nov 16, 2009
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? etc I plan to have two os, ubuntu 9.10 and win 7. ubuntu for office work and light programming, and win 7 for gaming. So the video card should be nVidia to have better linux support. I hope the machine can fulfill the recommended specs of Dragon Age:
RECOMMENDED SPECS
* CPU: Intel Core 2 Quad 2.4Ghz Processor or equivalent
* RAM: 4 GB (Vista) or 2 GB (XP)
* VIDEO: ATI 3850 512 MB or greater
NVIDIA 8800GTS 512 MB or greater
AMD Phenom II X3 Triple-Core 2.8 GHz or greater
DVD ROM (Physical copy)
20 GB HD space
2) What's your budget? Are tax and shipping included? 800USD, tax and shipping included.
3) Where do you live? Tennessee
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
everything, maybe except a mouse.
none
6) Will you be overclocking?
probably not
22, at 1680x1050, but I can turn off the system eye-candies. Just want to make sure I can run the current games smoothly with the lowest visual effect.
now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
nothing special
10) Do you already have a legit and reusable/transferable OS key/license?
I can buy win 7 from a special offer, and it's price is not included in the budget.
Here is what I have in mind (mainly from this post):
MSI N250GTS TwinFrozr 1G OC GeForce GTS 250 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127445
OCZ Gold 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500) Dual Channel Kit Desktop Memory Model OCZ3G10664GK
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227346
Hanns·G Hi-221DPB Black 22" 5ms Widescreen LCD Monitor
http://www.newegg.com/Product/Product.aspx?Item=N82E16824254035
Sony Optiarc Black IDE DVD-ROM Drive Model DDU1678A - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827131061
antec 300 and antec earthwatts ea650
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.285167
phenom 2 x3 720 and GIGABYTE GA-MA785GMT-UD2H bundle
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.291502
Seagate Barracuda 7200.12 ST3500418AS 500GB
http://www.newegg.com/Product/Product.aspx?&Item=N82E16822148395
Am I missing something here?
Also I need a long cable, any opinion on this one?
http://www.newegg.com/Product/Produ...8&cm_re=ethernet_cable-_-12-189-038-_-Product
RECOMMENDED SPECS
20 GB HD space
none
probably not
now
nothing special
