Hello all, I'm hoping for someone knowledgeable to help me here as I am at a loss.
So I built the following 2 weeks ago (all new components):
Windows 7 Home Premium
G.SKILL Ares Series 8GB (2 x 4GB) PC3 12800 Model F3-1600C8D-8GAB
AMD A4-3400 Llano 2.7GHz AD3400OJHXBOX
ASRock A55M-HVS FM1 AMD A55 (Hudson D2) HDMI Micro ATX AMD Motherboard
RAIDMAX Altas ATX-295WBP w/500watt PS
ASUS 24X DVD Burner DRW-24B1ST/BLK/B/AS - OEM
Seagate Barracuda Green ST2000DL003 2TB 5900 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
I am using the onboard APU via HDMI out to an Acer 23.6" G245HD monitor, as well as to a 73" mitsubishi using HDMI.
System booted up first try, loaded up Windows, and updated everything to SP1. The only software I installed was Microsoft Security Essentials, WinRAR, Reader, VLC player, and that's about it. I did not install the bloatware that came with the mobo, just the drivers.
The very first time I surfed the web I began having CONSTANT freezing with the error "display driver stopped responding and has recovered". The error occurs maybe once every ten seconds, starts happening almost non-stop, and shortly the driver cannot respond and it bluescreens and restarts.
This error only occurs when I surf. It doesn't matter what I surf, or how long I surf for. All I have to do is open a browser! It is NOT heat related. It literally happens the instant I open a browser or a D3D game.
It begins immediately after starting a browser (IE, Chrome, and Firefox all have the same behavior) although I swear I see it happen more often with Firefox. However, aside from the surfing errors I am able to watch videos for hours, even at 1080p, as well as play games which don't require D3D (such as Hoyle puzzle games). However, any game which uses D3D causes this error as well.
I searched this error and followed all the suggestions I could find:
I updated the motherboard BIOS from 1.00 to 1.30 (latest version).
I made sure the onboard graphics are the default in BIOS, and I tried different shared RAM settings.
I made sure the voltages to CPU, RAM, and NB are within acceptable limits (all steady within 2% of proper voltage).
I re-seated the RAM, several times, and tried running the system with one stick, then the other, trying both slots etc.
I updated all drivers to the latest versions, and I used the drivers from AMD, not from the MB install disk or windows update.
I then uninstalled the video drivers, used a driver cleaner, and reinstalled.
I then tried rolling back the video drivers to earlier versions and no matter what driver I used the error continues.
I tried a different power supply.
I tried different monitor cables - VGA, HDMI-to-DVI-D, etc... no difference.
I tested the RAM using Windows diagnostic and it found no errors.
I installed the hotfix from MS which is supposed to alter the timeout period and alleviate this error - no change.
I have done a clean Windows 7 install to a freshly formatted HDD 4 times now(!) using different SATA cables and ports.
etc etc etc
So during all this testing, I notice something strange: the system operates PERFECTLY when using default VGA drivers! No errors, no freezing, and surfing is fine! But then my resolution is limited to 1400x1050, as well as having the limitations of the VGA driver. The strange behavior and error ONLY occurs when using AMD or NVidia drivers.
NVidia drivers? Wait, what??
Ok... so last week I figured the issue must lie with the onboard graphics, so I broke down and bought an EVGA 01G-P3-1556-RX GeForce GTX 550 Ti (Fermi) 1GB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card ... made sure BIOS initializes the PCIe slot first... and yes, I used a driver cleaner after uninstalling the AMD graphics drivers before installing the NVidia card... and used the latest drivers from NVidia's website (306.97)...
and NO CHANGE.
Same error. Same behavior. I feel like I want to scream or cry at this point.
Forgive the long post...but...help? Please? Is my mobo faulty? Am I faulty? What am I missing? Thanks in advance!
etc etc etc
and NO CHANGE.
