I just installed everything but my processor in my new P180 and don't know if there is a problem or not.
Power Supply: Turbo-Cool 510 Series by PC Power and Cooling
Motherboard: P5W DH Deluxe
Memory: 2 x 1 GB Ballistix
I plugged everything in: Fans, 24 pin to motherboard, 4 pin to motherboard, powersupply to 7900GTO, powersupply to Audigy 4. When I press the on button on the power supply, the green light came on the motherboard but no fans or even the powersupply started spinning. Is there a problem with the powersupply or is this normal until the CPU is installed?
Thanks!
(note: I posted this here because I figured all those motherboard guru's would know if the motherboard is responsable for letting the PSU know that it can start powering or not)
Thanks!
