please help :'( (upgrades)
citizenhipster
My last computer went through 3 motherboards, 1 power supply, and 1 video card in 2 years.
Finally, today, I'm thinking that this "computer" (or just the case itself) was cursed.
So, after being frustrated beyond belief, I am going to attempt to build a new computer.
what I am purchasing:
new case.
new power supply.
new motherboard.
new CPU.
i just bought a new video card which may not be what i'd like, but it'll have to do, as I am very low on cash. the video card is a sis xabre 400 by transcend.
anyhow, i'm looking to spend under $300 for all of this. and if i work it right, i expect to pay around $220.
i do not know if i would like to go Intel, or AMD. however, my last system was AMD, and I am thinking that I should go intel, now.
I would appreciate any suggestions on RELIABLE hardware.
Thanks a great deal!
if you expect to spend under 300, and preferably closer to 220, I don't think you'll get much if you do go pentium.
usually, bang for the buck goes to AMD, excluding the 2.4c's which oc well above 3ghz, but those are still ~$160 at newegg, not exactly gonna keep you in that price range
well i was thinking maybe..
$150 for the cpu/mobo
$50 for the power supply
$50 for the case
or maybe $40 for both power supply and case?
but i would just like it to be under $300, that's my main concern.
Thanks though.
You get what you pay for in some cases but if you can get around $300, here are some choice parts which I think you will be happy with in the long run. Just by some good ram in the future to complement it.
ANTEC SONATA with 380W PSU
http://www.newegg.com/app/ViewProdu...1-129-127&catalog=7&manufactory=BROWSE&depa=1
Asus nForce2 Ultra 400 Chipset
http://www.newegg.com/app/ViewProdu...-131-455&catalog=22&manufactory=BROWSE&depa=0
AMD Athlon XP 2500+ Retail
http://www.newegg.com/app/ViewProdu...03-379&catalog=343&manufactory=BROWSE&depa=11
Everything should come to around $280 shipped from Newegg and tax free depending on where you live.
i second this option. i have a slight variation of it, and i couldnt be happier. one point tho, you might want to consider i slightly cheaper antect case and psu comb (maybe the slk3700amb which i have and love, comes with a 350w psu) and invest in a good, quiet heatsink and HSF
