HardForumer
- Oct 1, 2011
I have already installed my 4 SATA devices which are Crucial M4 64GB (OS in already installed in it) 2x Samsung SpinPoint F3s, and the LG BD writer.
I want to set up the 2 F3s in RAID 0, and put everything else there, leaving just the OS in the SSD.
My manual is crap, it doesn't explain what to do really well, I can't understand it.
So, My MoBo is an ASUS P8Z68-V PRO, and the 2 HDDs that I want to put on RAID mode are on SATA3G_3 and SATA3G_4 ports.
It's set up like this:
SATA6G_1 (White port) - M4
SATA6G_2 (White port) - Nothing
SATA3G_3 (Light Blue port) - Samsung F3
SATA3G_4 (Light Blue port) - Samsung F3
SATA3G_5 (Light Blue port) - LG BH12 BD-RE
SATA3G_6 (Light Blue port) - Nothing
So that means everything was detected by the mobo.
When I go into windows 7 though, it only shows the SSD and the optical drive. Can't find the HDDs anywhere.
I went back into the BIOS and they're there on the same ports I mentioned above.
How do I set up RAID mode on the HDDs (Which are not being used right now since windows 7 is in the SSD)?
