Please help or board is going to be returned
Hi, ive been having problems from the outset with this board and ill unfortunately have to return it unless anyone can make a suggestion of how i can resolve my issue. When the computer is on its bullet proof and never fails. The only issue is high cpu usage but i think that might be an OS problem that i can resolve. The problem is when i press the power on button there is a 2 second gap where nothing happens, then 50% of the time the computer starts normally. But the other 50% of the time the fans spin up and HDD light comes on but then it turns off, then on, then off, and so on, but never getting to the POST screen. Ive tried changing the ram, its definantly mounted correctly so not a grounding issue. Can anyone suggest antyhing else? If not the board will have to go back. The RAM is set to 1.85v in the bios even tho the board says it supports 1.8v so i will try changing that, but does anyone have another suggestion? Thanks very much
MSI P965 Neo
Core 2 Duo E6400
Antec Neo 500W PSU
Antec solo quiet case
2x DDR2 667Mhz RAM
PX7900 256MB Video Card
Seagate 7200 SATA Hard Disk
Maxtor IDE Hard disk
IDE DVD rewriter
Soundblaster XFi
i tried memtest86+ v1.65 and it did indeed return an error
Tst Pass Failing address Good Bad Err bits Count Chan
7 0 0003a542934 - 933.1MB 3598fb6f 3598fb4f 00000020 1
Cached Rsvd Mem Mem Map Cache EEC Test Pass Errors EEC Errors
2049M 276M e820-std On Off Std 1 1 0
What does this mean? Im new to memtest. Does this definantly mean a memory problem or perhaps a motherboard problem relating to the memory? I ask because this is the 2nd totally different set of memory that is causing the same intermittant starting problem. I didnt however, run memtest on my last ram. Thanks a lot!
Put the memory voltage up to 2.0-2.2V and try memtest86 again.
Just wanted to make sure, you're having these symptoms with everything stock right? Also, you flash to latest bios?
ive put the voltage up to 2.0v now and had the same problem again. Could it be harmful to put the voltage higher? And yeah ive flashed to the latest bios although apparently msi are releasing a newer one soon
