- Jul 29, 2011
Alright, I got the AMD Freesync demo going and Freesync does literally nothing. Only option that has an effect on the tearing is vsync on/off. Pretty conclusive to me, this shit don't work.
I wonder if your problem is specific to the manufacturer of your card. Like somehow they screwed up the Display Port itself and it's not properly transmitting VRR info.
Who makes it? Is it a reference card? I wonder if anyone else in out there has the same problem you have.
Its kinda funny how were all different....but i would have tried this DAY 1 lol![]()
I tried both and gsync looks much much much more fluid... to be honest I think you are just used to gsync..
Alright, I finally got it working. All I needed to do was go buy another GPU, motherboard, and CPU. I picked up an i5 4690k and a Z97 board along with the extra 290X, installed Windows 7 and the 15.7 WHQL and now it seems to work fine both in single card and crossfire configurations. Why it didn't work on my X99 or FM2 machine I have no idea.
Well did you try just the replacement gpu first?
So you bought a completely new system, that doesn't really tell you anything about which part it is that was the issue. I don't recall ever seeing anything about Freesync requiring specific cpu/motherboard combinations, so I sincerely doubt either one of those was the problem.
OP, having used both Gsync (before) and finally getting Freesync to work, what is your opinion on the way they feel. Which feels better, which would you recommend etc...?
