Folks,
I have this fairly old ATX chassis here I wish to put back into service after several years of non-use. It's very large, and I need this space for my 8800GTX cards coming in as well as the water-cooling I am about to try out.
As you will see in the big pic below, it's old school [H] from 1999. Abit BP6 motherboard, dual Celeron 366@550, 120cm fans. I bought the chassis off of Kyle's review, IIRC. It's a tank of a case and I'd love to keep using it.
I *believe* it's an old Lian-Li, and for some reason the model number strikes me as being something like ??-030 or ??-040...
That being said, I need to find some screwless 5.25-inch bay rails -- you know, the kind of things you attach to a bay device (CD-ROM), so they simply slide into the chassis and "click" into place.
Here is a photo of the rails I need:
This case has been in the garage since 2002, but there's no reason I can't clean it up, stick a radiator, a pump, and all-new guts (including a new power supply, yes) and make it modern once more. Since chassis that can hold dual 8800GTX's are scarce (and expensive), this makes the most sense for me.
If anyone can help -- please do! I need some more of these rails for the new parts this chassis is to receive.
Inside:
Front:
Thanks in advance, folks!
Inside:
Front:
