Photoshop / Rendering / Cad / AutoCAD / AutoDesk / 3dsMax
My Max Budget is $3200 Including Tax & Shipping
U.S California , Beverly Hills
4) What exact parts do you need for that budget?
I Need a CPU, Power Supply & Motherboard + Video Card + Ram + SSD & Hard Drives ( 1 SSD & 2 or 3 Backup Hard Drives 1TB Capacity Per HDD & 480GB + For SSD. I need a fast SSD that will last a while and can handle a lot of read and writes daily. mostly between 5 - 150mb size files. about 500 writes per day in that size
Reusing My Full Tower Atx Case If Possible & Asus DVDRW Drive.
6) Will you be overclocking?
No
Have Three 24" Monitors 1920x1080 Each. Although I'm gonna be only using 2.
As soon as possible
, hopefully in less than a week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Need Raid 1 or 5 if i can fit it in my budget.
I have a retail windows 7 ultimate box & windows 8 box. They're both 64bit.
I mainly need a strong system to use for rendering & for Photoshop & Web Browsing. But obviously rendering is my priority.
Thanks for the help
No
As soon as possible
Thanks for the help
