Please help me before I go insane!!!
I'm not even sure if this is where I should be posting this because I'm not exactly sure what the problem is but please allow me to tell you the nightmare I'm currently experiencing. I have built about 8 computers over the last 12 years and I've never seen anything like it.
I built this PC about 7 months ago and it ran great. Well about three weeks ago I sat down to turn my computer on and nothing happened. I thought hmmm the power supply must have blown so I promptly ordered a new power supply (the same model and wattage) from newegg. I installed it right away and when I pushed the power button, nothing happened. Ok, so after double checking all of my connections I assumed that I must have a bad mobo. I sent the board back to AsRock and they sent me a replacement within 2 weeks. I installed the replacement motherboard, put the pc back together and when I pressed the power button, guess what...nothing happened. I thought well maybe the power supply newegg sent me was bad so I ordered ANOTHER power supply, installed it and again - no signs of life at all when I press the power button. I finally said the hell with it and took the damn thing into a computer repair shop today. The guy tested the power switch and the power supply and said they were both fine. His diagnosis was that i probably had a bad motherboard....again. I called AsRock about another RMA and they want me to send my CPU and my memory along with the board and I don't understand how those two components have any bearing on my problem. Correct me if I'm wrong, but the damn thing should still power up even without a CPU and memory, it just won't post right? Furthermore, the replacement board was supposedly tested and I'm really skeptical that they sent me a replacement board with the exact same problem. I don't want to go through the trouble of another RMA if the problem lies elsewhere.
Sorry to be so long winded but, I wanted to get some advice from the real professionals which are you guys. The computer is showing no signs of life at all- no lights on the board, no lan activity- nothing. I tried plugging it in at different outlets, using the reset switch and the smart power button on the motherboard and I get nothing. I'm just totally stumped and I'm ready to drive my car over this damn computer. Many thanks for any help.
Cooler Master HAF X Case
i7 3770k
AsRock Fatal1ty Z68 Pro Mobo
16 gb G Skill Sniper series Memory
eVGA GTX 680 SLI
Thermaltake 850 Watt power supply
Mushkin SSD
WD hard drive
FYI you can check a power supply with a paper clip by connecting the green and any black wire together on the 20/24 pin connector. It should power right up unless there is an issue with it.
Then when your power supply is proven working, you can bridge the two connectors normally going to your power button to see if its a case or motherboard issue.
That woulda saved you 50 RMA's and a trip to the computer repair man.
I did the paperclip test and the power supply did fire up but I read that's not a fail safe method for proving a power supply is functioning properly with other components so that's why I went ahead and bought one. Regarding your comment about bridging the two connectors together going to the power button, can you elaborate on that? What do you mean by bridging them together?
Yes, the mobo should be able to power up with NO memory or CPU... No is stressed because they may be causing an issue while still installed. Start removing any and all peripherals one by one. When the system does something different, you've likely found your culprit.
Or if you feel like tearing it all down, start with just the mobo, PSU & display (no case, CPU, mem, HDD's, other cards, USB devices or cables of any sort) - then add components one by one until things change.
I'd say chances of guessing at what the bad part is, getting a replacement, having the replacement act the same way and actually be bad is pretty slim.
Also, make sure it's not an issue with that outlet or power cord. Sounds simple, but often can be a problem.
Wasn't me, but I'll answer - literally bridge the two pins together with a small screwdriver or anything conductive. The power button is just a momentary switch. You'll need the PSU plugged in, so be careful. If the connectors on your mobo aren't labeled, you'll want to consult the user guide for the mobo to make sure you've got the correct pins.
Thanks man, I will definitely do that. I'm assuming it won't damage the mobo if i turn it on without the cpu installed? Also, I already ruled out the outlet and power cord by changing those.
I would have to second what 1911 Shootist said to troubleshoot this one is start removing parts since you have already replace some of the main possible problems being PSU or MB.
I 'd put the motherboard on its own cardboard box and use the screwdriver passing it between the mobo pins in order to power it on, like the previous poster suggested.
The times i had where the mobo would seem dead, where all cases, where something was shortcircuiting the motherboard, being a small screw underneath or a badly positioned i/o shield that somehow was involved.
With the cardboard, you should see if it works. I usually put CPU, RAM and VGA and then fire it up with the screwdriver. Never failed me.
I took your advice and have narrowed it down to the case. I know this because I pulled the mobo out and sat it on the cardboard box and it fired right up. I can even sit it inside the case and it still works. The problem is whenever I put the screws in the mobo. So I'm assuming that somehow the case is shorting the mobo whenever it makes contact. I'm not sure how this happened, But the main question is how can I fix it without buying a new case? I really hope I can fix it because it's a $230.00 case.
You need to double, triple check the standoff locations. You are using standoffs?
Yes I am using standoffs. However, I have some extras so not only will I check them, I will also replace them. Keep in mind this computer functioned normally for 7 months, it just decided not to turn on one day. I'm no expert on electricity but i'm thinking there must have been some kind of abnormal electrical spike or something that changed the properties of either the case or hopefully just the standoffs. Thanks for the advice, I will give it a try as soon as I get home from work.
Glad i could help.
The problem is the "extra" standoffs. They make contact with the lower side of the motherboard, shorting it. You ONLY need to have installed the standoffs that correspond to the holes of the motherboards. ALL other standoffs, you need to REMOVE them from the case. That's what causing the shortings.
Also be sure the I/O shield is perfectly positioned. Sometimes it's uneven and can lead to situations where the motherboard isn't "sitting" perfectly alligned with the holes, with the result that one end of the mobo is screwed down well and another is being screwed with difficulty, that can lead to bending and uneven sitting of the motherboard. With a perfectly alligned i-o shield, all holes should be perfectly aligned to the standoffs and screwing all of them should be equally easy. Don't tighten completely the screws on one part. Screw all screws loosely first and then start tightening them at different ends of the motherboard, so all sides of the mobo get equal strain.
Oh, make also sure that all standoffs are equally tightened in position before you screw the motherboard. Sometimes, a standoff, after months can become loose and after you screw, instead of screwing the mobo down, it pulls the standoff up.
I just wanted to thank all of you guys for your help. I found the culprit last night by adding individual components until I lost power. Turns out it was a faulty USB port in the case. Once I unplugged that from the motherboard it ran perfectly. I would have never figured it out without your advice and I'm a lot more knowledgeable on the subject now thanks to your help. Have a Merry Christmas and thanks again!
bingo, pull the USB board and cable and inspect them closely, somehow 5V is shorting to ground there, pinched cable? foreign object in port?
Glad you found the culprit! Hardware issues like these that appear like "mystery cases" have driven me mad in the past too. Usually it's the dumbest thing that you never think of.
