This is an old HD well it says 2001 as manf date. It's an 60gig ibm deskstar 7200rpm drive. It worked well for the past 4 -5 years untill yesterday. Recently, I have installed new video card, PSU, rouded IDE cable ,etc and I've been getting frequent system hang, during games mostly. I thought it was the video card + system OC related so I just kept on playing around with the FSB and ram timing. Finally yesterday I starting to get very slow windows boot up and then it would crash after about 1 hour or so of usage, eventually it won;'t boot up anymore.
Long story short, I was able to use the "freezing" trick to recover all my critical data. A 20 minutes in the fridge would make the HD work again. Based on different trials, it seems the HD will perform well when it's freezing cold, once I have backed up all the data and HD starts to warm up it will eventually become sluggish. Taking forever to read data and then it would just die.
I am just wondering, what could have possibily be causing the problem? Internal components got expanded due to the heat? Will it work as "normal" again if I freeze it long enough?
I am in the market for a new HD. I think I am going to try the seagate one this time.
