I have recently upgraded from a single-core AMD CPU to a dual-core AMD CPU, and upgraded my RAM (speed and size), and at the same time I addressed some heat-related issues in my GeForce 6800 GT (the assembly was getting clogged with dust on the inside). I'm running Windows XP, fully updated.
Now, when I try to run a game, I experience the following symptoms:
1. Locks, freezes and pauses in video, usually crashing within a few seconds to a few minutes. When freezing, the symptoms can range from minor graphical glitches to a major graphics freeze and sometimes even the monitor shuts down as if it is no longer getting a signal from the card.
2. Sound stuttering during the crashes, but just intermittent stuttering. The video could be totally frozen, but the sound keeps going as if the program was still running except for the sound stuttering up about every 5-10 seconds--that is except when the game really crashes hard.
Windows itself runs fine, but Studio 10 is also locking up on me either at load or when I am working on video.
So what have i done?
Well, I did the aforementioned CPU upgrade, from something like a 3200+ single core to a 4200+ dual core. After I started researching some of the dual-core issues, I downloaded the AMD Processor Driver update and Dual-Core Optimizer from their web site, as well as the Microsoft Hotfix.
Before the upgrade I didn't realize how bad the temps were in my video card, up to an topping 100C at load. I got all the dust out and put Arctic Silver down on the GPU. Temps now at idle at around 55C--I haven't really measured it at load yet, but it's way, way lower than it was before.
I have tried a lot of different drivers. The newest beta drivers, the latest WHQL drivers, older drivers (back to the 100s). None of them alleviate the symptoms.
I removed a wireless network card I wasn't using before so I could move my sound card up a slot to see if that might shift resources around and help. It did not. I also went into my bios and disabled stuff I'm not using--Parallel port, serial port, game port, etc.
I tried using Rivetuner to disable fastwrites. No help, the Crysis demo showed that little text in the upper right corner about it being a demo, but didn't even get to the EA logo.
I'm going crazy here. I didn't upgrade my system so that I couldn't play games! The games I'm using to test are: Madden '08, Crysis demo, Neverwinter Nights. Have I missed something obvious? Something not obvious?
Thanks much for any information provided.
