Bipolarbear
- Dec 25, 2008
I'm having a few problems with my newly acquired system and was hoping that someone here might be able to help me come up with a solution.+System contains an i7 d0, 3x2gb Gskill NQ PC12800 ram (9-9-9-24), a DFI Lanparty T3H6 mini atx motherboard, noctua nhu9b se cooler, gtx 280 and a couple of SATA hard drives + 1x IDE DVD writer, powered by a SuperFlower 750w 80+ PSU.
+The build has been nothing but trouble from the start. Firstly, the case (Lian-Li v350) required some serious modifications to fit everything in, then I had a problem with the CPU not clocking up from+a 12x multiplier in Windows 7. Turned out this was a BIOS issue, so I upgraded to the latest one from the DFI website and the multiplier increased as it should.+
Unfortunately, somewhere around this stage some serious instabilities set in. At the moment, 9/10 times the system will reboot spontaneously back to post as it tries to load windows, in the EXACT same time in the loading process. On the rare occasion it makes it to the desktop, it rarely lasts more than 5 minutes before BSODing with a variety of different STOP codes.+I reverted to the next most recent bios (which doesn't support proper multiplier under windows 7, but I thought it might bring back stability) but the problem remains.
I tried running with one stick of ram in (in the correct channel for this mode of operation) to no avail. I reinstalled Windows 7 on a different partition and the same problem occurs.+ I'm at work now and plan to try Windows XP when I get home but I really want to be able to run 7 as it will be my regular use machine.
+I have a few possible ideas about what the problem could be. Firstly, could it be something to do with the AHCI/IDE setting? I have it set to AHCI right now but the problem does not seem to go away if I set it to IDE. It may also perhaps be something to do with the bios settings themselves, though clearing the bios to defaults does not make the problem go away.
People have talked about changing the MEM LOWGAP setting but I have it set to "1024" at the moment, as I believe it should be. Voltages are all at default, I have tried setting it to 1.2v for both vid and vtt to no effect. I have followed all the guides for i7 clocking (even though I am running at stock, making sure I observe ratios between multipliers etc) but the DFI bios is almost hilariously complicated.+
If anyone has any insight into this issue or has had experience with a DFI board and a i7 920 (and could post their settings, perhaps?) I'd be very, very grateful. I have spent a lot of money and time on this system and it's incredibly frustrating having these issues.+
Cheers
Cheers
