Please help building a budget gaming rig
loss4words
I don't even know if it's possible but I think I should give it a try. My budget is currently $500. Things that I do have:
15 inch LCD Monitor
80 GB 7200 rpm IDE hard drive
keyboard, mouse
Windows Vista Business Edition
I'm REALLY a newbie and don't even know where to begin. Please help :)
In that price range I honestly think you are better off getting a Dell than trying to build it.
$500?
Xclio 500W psu $50
http://www.newegg.com/Product/Product.aspx?Item=N82E16817189005
Coolermaster 330 Elite Case (decent case, tool-less component mounting, a couple of sharp edges on pci slot blanks) $30 AR
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119115
e4400 cpu (mine did 3ghz easy, now at 3.4ghz) $126 http://www.newegg.com/Product/Product.aspx?Item=N82E16819115014
BFG 7900GS OC, $120 AR http://www.newegg.com/Product/Product.aspx?Item=N82E16814143070
Samsung DVD burner $31
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151153
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 675 (will run DDR2 800 easy, with e4400 and a 10X multi you don't need a high fsb) $65 AR (or Corsair 800 for $75 AR)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145015
XFX 650i Ultra mobo, $79 AR - solid enough mobo, I've added a fan to the NB sink
http://www.newegg.com/Product/Product.aspx?Item=N82E16813141004
Total: $501 after rebate, before shipping and tax
If you need to save a bit more, drop the cpu to an e2160 - $90 http://www.newegg.com/Product/Product.aspx?Item=N82E16819116036
Thanks, to both of you.
I'd rather build a system myself than buying something from Dell or otherwise. What would you say is a reasonable price to spend for a gaming rig that's not too expensive? I'm hoping to play most of today's games, and hopefully something that could be upgradable in the future to meet system specs of games like Crysis, etc, so I guess my CPU has to be able to go past 3.0 Ghz mark....
I'm also a newbie to building computers, and I've never tried overclocking so please keep that in mind too :)
I noticed that a fan and a heat sink is in a package with a CPU that markintosh linked to. Will that really be enough to keep the system cool enough if I tried to play a graphic intensive games? How about case fans?
Thank you very much for trying to help me out. I really appreciate it :)
The stock heat sink fan is good enough if you do not over-clock. If you do over-clock, you will want a good 3rd party HSF like a Tuniq, Zalman, Scythe, Thermalright, etc...
To give you a good ballpark, the rig in my signature (not counting the future stuff) cost me $904 just 2 weeks ago. That includes optical drive, case, etc... The vid card I got off ebay.
Frogger - out of curiosity... why is it better? Doesn't it lack RAID capability? Does it have something that makes up for that?
The case above has decent airflow. Adding another 120mm fan in the front helps alot. There's a side panel opening and a cpu-cone that is meant to direct cold air into the heatsink fan. On the stock cpu heatsink you should be able to get decent temps up to about 3 ghz.
Frogger - out of curiosity... why is it better? Doesn't it lack RAID capability? Does it have something that makes up for that?.
It doesn't sound like the OP needs RAID and the since the IP35 is a P35 chipset motherboard, we know for sure that it will support the new Yorkfield and Wolfdale CPUs in case the OP plans to upgrade.
Now that taken care of, here's an alternative build list that doesn't rely on rebates:
Intel Core 2 Duo E4400 CPU - $119
GIGABYTE GA-P35-DS3L Intel P35 Motherboard - $88
A-Data ADQVE1A16K 2 x 1GB DDR2 800 RAM - $78
eVGA 256-P2-N615-TX GeForce 7600GT 256MB PCI-E Video Card - $90
Samsung SH-203B 20X DVD±R SATA DVD Burner - $31
XCLIO Goodpower 500W PSU - $50
Cooler Master Elite 330 RC-330-KKN1-GP ATX Case $40
Total: $496 Plus tax and shipping
Since you only have a 15" LCD monitor all you really need is the 7600GT. If you want a bit more headroom for future video games, go with the x1950GT. It's a bit faster and cheaper than that 7900GS card that markintosh13 linked to but it will cost you another $25:
Sapphire 100199L Radeon X1950GT 256MB PCI-E Video Card - $115
The DS3L that I linked to is a decent and stable motherboard that overclocks pretty well from what I've read so far and will support Intel's new Penryn CPUs.
Oh and for case fans, I recommend getting one or two if you want of these:
120mm Yate Loon D12SL-12 Case Fan - $3.50
The P35 chipset is the latest one from Intel. It is stable, over-clockable and will support the new 45nm chips coming out next year. It is the preferred chipset if you do not need SLI. The Abit IP35-E is the cheapest P35 mobo out right now, but is very good quality. I have the Pro version and I can tell you they are rock solid.
Thanks a lot, Danny. I've almost few clicks away from purchasing parts that you've suggested. I just have a few questions:
Is this system upgradable? For example, if I wanted to add a better graphics card or something like a faster CPU in the future, would this system support it? I really wish I could play games like Crysis and Bioshock, and I'm not sure if this configuration would support it.
As frogger suggested, if I overclock, I would need a 3rd party HSF. What is the best one I could use? I've heard good things about Zalman, but that's all...
I'm really excited about this. Not only will it let me play the latest games but this is also a great learning experience. Thank you very much :)
The best thing to do research on products then use the forums to clarify and questions you have. At least thats what I do since I'm a huge noob. :p
Zalman's are good, but the one that seems to be the best value right now is the Scythe Ninja Rev. B. It can be found for $35 and works great.
I wouldn't make the gpu purchase on the basis of your current 15" monitor.
Larger LCDs are getting cheaper all the time... and you could start dropping Xmas gift hints or whatever, early.
I had a 7600GT... and yes it's okay. But it really requires a volt mod to seriously shine - it's 128 bit memory really holds back it's texture performance.
I'd still say go for something better.
As for aftermarket cooling... with the case I suggested, an extra 120mm front fan... the stock cooler would be fine for a 2.7 - 3ghz OC. With overclocking, once you start hitting the upper end of the cpu's capability... the temps will ramp with the extra vcore. With an aftermarket cooler, you'll bring the temps back down, but the final overclock wall will probably be only another 200 - 400mhz away. So if you want to hit 3.3ghz or so, a $22 Arctic Freezer 7 Pro will to the job - a substantially more expensive cooler might get you 3.4 ghz or something, but remember that it's diminishing returns at that point.
Yes, it is upgradable. That power supply can easily support an 8800GTS, maybe a GTX. The motherboard, like what has been said at least two times, is a P35 chipset motherboard, which mean it will support Intel's new Wolfdale and Yorkfield CPUs.
With the E4400, like markintosh13 has already said, the Arctic Cooling Freezer 7 Pro is a good choice:
Arctic Cooling Freezer 7 Pro HSF - $22
Do take my advice about the 7600GT and x1950GT. If you want a bit extra power for future video games, go with the x1950GT. But the 7600GT should be able to handle many future games as long as you turn down a good number of settings.
650i chipset mobos have had bios updates that support 45nm cpus btw. Bit theoretical, because we seem to be discussing lower end cpus here.
Here's some benchmark charts on reasonably up to date games that includes a 7600GT, a 7900GS, an overclocked 7900GS and an X1950GT (the article itself is in french, but the charts are pretty clear - finding benchies with all three cards isn't easy).
http://www.clubic.com/article-70541-4-ati-radeon-x1950-gt-vs-nvidia-geforce-7900-gs.html
I can't say 7600GT looks particularly outstanding, even at 1280x1024, granted the eyecandy is turned on - but eyecandy is so nice. And I can't say the X1950GT owns the 7900GS either - and if i recall the reviews I looked at before buying a 7900GS, the 7900GS overclocks better too. My 7600GT was nice for older games like Counter Strike Source, but with the heavy emphasis on eyecandy in newer games... I can't recommend it anymore.
My 7600GT overclocked from 560mhz to 621 or so with Coolbits. With a graphite pencil mod, it hit 666mhz (the evil overclock).
My 7900GS clocked up from 520mhz stock clocks to 581mhz with Coolbits, and with a conductive ink mod (very very easy btw) it hit 681mhz core - which made it fly.
Go for the 7600GT for now, and when Crysis comes out, NVIDIA will have their new cards out, so you can upgrade then. Just sell the 7600GT to help offset the cost of the new card. The 7600GT should be fine for your size monitor until Crysis and the new cards come out. Its best to not buy for the future, because nobody can predict it. Wait til the game you want to play comes out, then buy the best card you could afford for it. Its hard suggesting a good card right now, because NVIDIA's new cards are just around the corner. So, the best thing to do is get the cheapest card you can that will tide you over until you can upgrade for the game you want to play.
Yes, the systems suggested are upgradable.
I'd stick with the P35 suggestion, because it runs cooler than the 650i. Also, make sure the board you choose as all the features you need (eg. parallel port if you have an old printer, serial port if you have an old UPS, PS2 ports if you have PS2 keyboard/mouse, etc).
TAKE YOUR TIME. Don't rush into buying this system just yet. Read around the forums and check out other people's builds. See how their thought process leads them to which parts.
Well, I've ordered everything that Danny suggested. I should have everything tomorrow and I'm very excited to start building :). I just have one question though. Do I need to buy a separate NIC card to have wireless access to internet or will the onboard 10/100/1000 do the job? The computer that I'm using right now is connected to a Linksys router which is connected to my DSL modem.
You'll need a wireless card if you need wireless access, but I'm a bit confused as the current setup you described is not wireless... you'd just connect to the onboard NIC.
I also have a laptop that I use. I'm using a router to get wireless internet access to that laptop.
Do you have any good suggestions for a wireless nic?
Any good suggestions for a wireless nic?
If you have a Fry's nearby, I've had good luck with their Airlink 101 Wireless PCI Adapter. It goes on sale for $10 or so every few weeks or so.
If you have the option of wired or wireless for the desktop there is /no/ reason to go wireless. Wired is more reliable, more secure, faster... no down side.
I've used several airlinks from Fry's, and while all 3 of mine ($9.99 kind) still work after a couple years of usage, my homie has been through 3 of them already for his one machine... his tends to keep dying after a year... but $10 a pop doesnt bug him, lol.
Though, I agree, if you can, use the wire.
Well, I got all the parts today except the case fan which I should have some time next week. And of course, as you would imagine, I'm doing something wrong already and I need help :)
I'm pretty sure I've connected everything the right way and I've followed the motherboard's manual instructions to connect everything but it just won't boot. I see the LED light on the PSU itself but that's the only light I see. Nothing starts up..no fans, no nothing. I've disconnected everything and connected it back but still the same. I won't give up but I really need some suggestions, please. :(
Jump start the PSU to make sure it will power on and stay on. Make sure you have all the power cables plugged into the mobo that need to be plugged in, espeically the 12V 4pin CPU connector.
Is the board mounted into the case already? If so, check for any grounding points.
Reseat the CPU. Try a single stick of RAM. Try with no RAM, and you should hear some error beeps if you have a system speaker plugged in or if the board has an onboard speaker. Try it without a vidcard, and you should, again, hear some error beeps.
The best thing to do is all of the above, outside of the case, with the board on top of its own box, with just the essentials plugged in -- you just need it to POST.
In addition I would check your power switch connector. Swap the orientation and see if that works. Seems to me that could be an easy solution if everything else is plugged in right. Btw enginurd, my new Intel system that you helped me spec out is doing wonderfully. Quite a large upgrade ;) I'll have to update my sig soon, though the rig is similar to yours :)
The orientation shouldn't matter for the power or reset switch jumpers -- it only matters for LEDs and the speaker. What you could do to test this is use a screwdriver to jump the two connectors instead of using the switch.
Ah yes, I blame it being 2am in the morning! I was thinking along the lines of jumping it, in case the switch/switch connector was faulty or making bad contact.
Also, the power switch on the back of the PSU is in the "on" position, correct? I have had it off a few times and thought "oh no" when my system didn't come on, only to learn that I was being a n00b :)
I've tried everything you guys suggested and still nothing. The PSU led light stays on but nothing starts up. I took out the CPU and put it back in, tried with one RAM module and no RAM modules, took out the optical and hard drives, took out the GPU, made sure that all connections are how they're suppose to be according to the motherboard's manual...I have no idea what else to do :(
Have you tried starting it with just the CPU, Ram, and Video card in? If that doesn't work I would take it out of the case and try it again with just those components.
So just to make sure I have it right - your PSU fan comes on but not the CPU fan?
Well, it turned out to be a bad PSU. Newegg shipped me an exact same new one and it works great so far.
Here are my specs:
Artic Cooler Freezer 7 Pro HSF
So far no problems. The video card has been having some incompatibility issues with 32-bit Vista Business, ie it would sometimes freeze on start up or I'd get a BSOD when I try to restart or shut down the computer, but after updating the drivers everything seems to be working fine and I get no more error messages. I know this isn't some end of the line system, but it should play most recent games. I also plan on using this machine for learning purposes so hopefully one day I could come on these forums and actually offer some advice instead of asking million questions :) Thanks a lot, guys.
