- May 18, 1997
We can fix that.No edit button?
No edit button?
I like the new look...it's not too different from the old...it just looks more crisp and clean with better lines...the fonts are also bigger...will take some getting used to after all the years of the old version but it's an improvement
agree it's a bit too different.. also i don't like that i can't see the actual post i'm quoting in the quick reply. and maybe it's just me but i feel the "report" button is either to big or stands out way to much, scrolling through threads all i see is the big report button..
Yeppers.....The quote button is the new multi quote button, for a single quote you just hit reply. I figured that out in about 5 seconds, not that hard.
Middle bottom.
I switched from the dark view to the light view, and it helped some. I really liked the old dark view, but I just can't get past the new font size and spacing. With the light view it's better, but still not great.
Not seeing it on a mobile device to edit a post. I see like, quote and reply. Edit is a must for posts, glad it will be fixed
so the main HardOCP page is still showing the old layout...any way to link directly to that page from the forums?
You have to go into your user profile and scroll down.....yeah, not the best design....I thought only Forum was revamped...
on the other hand, is there a way to log-out from mobile site? I really haven't found a way yet..
reply works but not multi quote in quick reply. You need to go advance to see multi wuote.
Also the report button should be on the right and the edit/reply/quote should be where the report is in my book.
What kind of phone do you have? My galaxy S5 has the triple bar thing as you can see in my screenshots.
It's here, the triple bar thing
I have a s4 and in the mobile version the EDIT doesn't appear.
It's there! Just really hard to see. Look close. It's directly beside how long ago you posted.
If you switch to the light view it's easy to see.
speaking of PM's...so you can no longer view 'Sent Messages' as a separate view?...it's now all lumped together as 1 giant 'conversation'?
Yes that's correct.speaking of PM's...so you can no longer view 'Sent Messages' as a separate view?...it's now all lumped together as 1 giant 'conversation'?
i like the look but i wish there was less empty space.
