Please critique this design ($800MAX)
MrJohnson
Hey yall, I need to know if and how this list can be improved. This computer will be used for heavy 3d rendering and some light gaming.
CASE.....Antec LifeStyle SONATA II....$99.99
http://www.newegg.com/product/product.asp?item=N82E16811129155
MOBO....Intel BOXDP35DPM..............$109.99
http://www.newegg.com/product/product.asp?item=N82E16813121314
PROC.....Intel Core 2 Duo E6320.........$165.50
http://www.newegg.com/product/product.asp?item=N82E16819115015
RAM.......(2x)Kingston 2GB (2 x 1GB)..$129.98
http://www.newegg.com/product/product.asp?item=N82E16820134046
VIDEO....MSI NX8600GTS...................$169.99
http://www.newegg.com/product/product.asp?item=N82E16814127287
HDD.......Seagate 7200.10 250GB........$69.99
http://www.newegg.com/product/product.asp?item=N82E16822148144
FAN.......VANTEC SF12025L...............$11.99
http://www.newegg.com/product/product.asp?item=N82E16811999614
SUBTOTAL.........................................$757.43
SHIPPING...........................................$26.83
TOTAL................................................$784.26
Drop the Sonata II.
Case: whatever you want fairly inexpensive. Something like this at $25. You could get down to $20 without too much trouble. If you get one that comes with a PSU, trash it and use the Goodpower. PSUs that come with cheap cases are almost always horrible.
PSU: XClio Goodpower 500 watt - $50 (Best "bang for the buck" PSU you can get right now)
Older design Antec PSUs like the one in that Sonata II are not very reliable. Getting the Goodpower gives you a few more reliable watts and saves you around $25, too.
DDR2-800 will be a great help if and when you OC, and isn't that much more. Another $30 for 4 GB if you get this $82 G.Skill 2GB kit instead of the Kingston.
An X1950XT will be faster than the 8600 in pretty much all DX9 applications, and I personally believe the severely crippled 8-series hardware used in the 8600 will be useless for DX10 native stuff anyway, so unless you can scrape up the extra $50-70 for an 8800 GTS, this is the card to go with. The 256MB version of the X1950XT should get you in under budget if you can't or don't feel the need to go for the 512MB X1950XT. X1950 Pros are cheaper, but slower.
You might also consider a 320GB drive for $80 rather than that 250GB for $70.
Sorry I forgot to mention that this machine will not ever be overclocked- which is why I chose the Intel board.
Then you need to pay up for a faster chip by default for what you'll be doing if you want longevity.
parts will be upgraded as I go. I'm just trying to get opinions on how to change this build as of now. Thank you for your opinions.
well i despise you for refusing to OC conroe, it takes <1min cause intel made ocing noob frendly...
ANYWAY
get a 6400.
get a cheaper case
get a better GFX.
ANYWAY
get a 6400.
get a cheaper case
get a better GFX.
sorry to make you hate me but thank you for the advice.
I'll pick out a cheaper case and get that PSU and upgrade to the 6400.
The better GFX, which one should I look for? I noticed the ATi one that was mentioned looks good. Can someone please tell me what DX10 is good for?
DX10 pretty much looks better. Most games for the next year or two will have DX9 "paths" that won't look quite as good in order to maintain compatibility with older hardware, so unless you're an avid gamer or think you might become one, it's something of a moot point.
I paid up for an 8800GTX and look forward to DX10 titles in the near future, but that's me. I pretty much built the machine in my sig for Bioshock.
An X1950 series ATi card will suit your purposes unless you are a heavy gamer. If you are, saving up for a 320 or 640MB 8800 GTS is a good idea, in order to get DX10 support. The 8600GTS you had picked out initially is slower than the X1950 in pretty much all DX9 applications and I don't believe it will have sufficient power to run DX10 applications at acceptable framerates and resolutions, so it is a not worth its cost to most at this time. The only people that would benefit from it would be those watching a great deal of HD video and not gaming at all, as it offers HD video decoding in hardware.
DX10 means better graphics for future video games. In another year or so, DX10 is going to become a bit more mainstream. However until then, the x1950Pro will suffice since you're a light gamer:
Sapphire 100176L Radeon X1950PRO 256MB PCI-E Video Card - $146
If you don't want to upgrade within the next year or two in order to play DX10 games or you become a fan of Crysis, then get this DX10 card that can beat the x1950Pro:
MSI NX8600GTS-T2D256E-OC GeForce 8600GTS 256MB PCI-E Video Card - $169
Now as for your mobo, I recommend you go with this mobo instead. It's cheaper and if you ever want to overclock in the future, this board will help:
GIGABYTE GA-965P-S3 Intel P965 Express Motherboard - $95
Stick with the E6300 for now since I'm assuming that you're planning to upgrade as you go. In July, Intel is dropping down prices on it's quad-core CPUs to $266. So in a few months you can upgrade to a quad core CPU. Hell, if you want to be able to upgrade to a quad core cheaply, drop the E6300 down to an E4300 and you should be set. I believe a quad-core CPU might help with 3D rendering. Correct me if I'm wrong please.
If you don't want to upgrade to a quad-core this year, then just get the E6420. Also, stick with your RAM choice since you're not going to overclock. DDR2 667 is fine for C2D stock. Also, you do know that you need a 64bit OS in order to use 4GB of RAM right?
As for the fan, don't buy that one. Instead go for a 120mm Yate Loon because they're one of the most quietest 120mm fans around, can push out a lot air and only costs $3.50 each!
http://jab-tech.com/YATE-LOON-120mm-Case-Fan-D12SL-12-pr-3009.html
$186 - Intel Core 2 Duo E6420 Conroe 2.13GHz
$95 - Gigabyte GA-965P-S3 Socket T (LGA 775) Intel P965 Express
$65 - Kingston 2GB (2x1GB) DDR2-667 KVR667D2N5K2/2G
$80 - Seagate Barracuda 7200.10 ST3320620AS 320GB 7200RPM SATA300 16MB Cache
$50 - XClio Goodpower 500W ATX 500W
$35 - Cooler Master RC-534-SWN1 Silver Steel ATX Mid-Tower w/ Side Window
$4 - Yate Loon 120mm 47cfm 28dB, sleeve bearing Case Fan, black - D12SL-12
$580 + tax and shipping
3D rendering usually needs some good GPU and CPU power, but you're on a tight budget and don't want to OC, so its up to you.
$290 - eVGA 320-P2-N811-AR GeForce 8800GTS 320MB ($20MIR)
$170 - MSI NX8600GTS-T2D256EZ HD GeForce 8600GTS 256MB
