Please assess my HTPC machine
Max-Powers
This is a HTPC that will be doing everything a HTPC does plus some decent gaming. This will be on a 42''+ LCD 1080p. The cost for everything on Newegg is around $1200. I will order the parts the first week of July, so it may change very slightly by then. I will also search for better prices. For now, everything can be gotten at newegg. I will do some overclocking
Operating System: Vista 64? I hear I need Vista 64 to be able to use 4GB ram, but some say Vista 64 is horrible. Should I just get it anyway?
Case: Silverstone LC20B
Motherboard: Gigabyte GA-MA790X UD4P
CPU: Phenom II X3 720 BE
CPU Cooler: Noctua NH-U9B (This may change)
Video Card: ASUS HD 4870
RAM: Corsair 4GB (2x 2GB) DDR2 800
Power Supply: CORSAIR CMPSU-650TX 650W
Hard Drive 1 WD 500 Gig
Hard Drive 2WD 1.5 TB
Blue-Ray DriveLITE-ON BD/HDDVD combo drive
Remote: Gyration Air Music Remote
What is some software that I would need to buy? Please tell me what you think and if there will be any compatibility issues that you see. I am fairly sure it has enough power to do what I want, but do you see anything that may be better or cheaper or unnecessary?
Sound System: Energy RC-10 fronts, Energy RC-mini center, Energy C-100 surrounds. Denon 1909 AVR.
For HTPC use, any 64bit OS sucks for HTPC use. Codec issue, mainly related to DXVA, is the main reason why 64bit OSes aren't recommended for HTPC use, judging from the general thoughts in the HTPC subforum. Example:
http://www.hardforum.com/showthread.php?t=1415560
Hit up this guide and check out CoreAVC Pro:
http://www.hardforum.com/showthread.php?t=1276654
Do you actually need an ATX setup? Do you actually need that much expansion room? Do you actually need to be able to game on this HTPC?
Oh and for the exact same price as the HD4870 512MB, you can get the faster GTX 260 with free shipping:
$170 - BFG Tech BFGEGTX260896OCE GeForce GTX 260 896MB PCI-E Video Card
