Hello,
I am planning to build a new computer to replace my Pentium 4 @ 2.8 GHz. I will mostly use the computer for math calculations/number crunching. I would also use it to play games and do some Photoshop/Corel Draw work on it. My budget is about $1500 with taxes. I do not need the monitor or the case. Below is a list of the things that I am planning to get:
Intel i7 920 CPU
Gigabyte GA-EX58-UD4P Motherboard
Corsair XMS3 Matched Triple 6 Gb DDR3 1600 8-8-8-24
BFG 275 GTX Video Card
OCZ Vertex 60 Gb SSD Drive
OCZ ModXStream Pro 700 W Power Supply
I would like an opinion if this is a good build or what I can improve, I am not sure about power supply, should I go for other brand and is 700 W maybe too much? Also for the video card should I go lower to lets say 260 GTX or higher to 285 GTX?
Thank you for any advice,
Mario
Intel i7 920 CPU
Mario
