Hey guys,
I am in the stages of planning a home theater for our new house that we will be moving into. It has quite the large media capable room that will be perfect for this application. I would love some critique on the components of my system, mainly the speakers, HTPC, and receiver.
Thanks.
For the receiver I was thinking the Onkyo TX-SR606
For my desktop speakers I currently have X-LS from www.av123.com their products have been nothing but gold to me so I was thinking
x-statik's for the fronts
x-voce for the center
x-omni's for the rears and maybe sides
MFW-15 subwoofer to top it all off
For the many damn cables required, I'm thinking to hit up monoprice.com because they're stuff is great quality and value.
To check out all the decora's, cables, connectors that I will be using to make my setup a clean, simple looking one go here http://benkipper.com/files/monoprice/cart.asp.htm
For my HTPC I already have the Case, HDD, Optical and RAM. I am going to order the CPU and motherboard soon.
Case - Awesome little HTPC case I got for $5 brand new
HDD - Hitachi 160GB SATA
PSU - Case has FSP 275w pre-installed
Optical - DVD-RW for now, Blu-Ray down the road
RAM - 2GB of Crucial Ballistix 1066
CPU - AMD Athlon 64 X2 5050E 45w
Mobo - ASUS M3A78-EM AMD 780G mATX AM2+ HDMI
Is the CPU and mobo a good choice? The CPU looked appealing because it is pretty fast, doesn't put out much heat and is cheap. The mobo I picked because it supported the proc, memory and has a respectable HDMI output. Comments please.
This is the layout I was thinking of
(sorry for the very crude ms paint drawing)
If you guys could give me some feedback it would be very appreciated!
Thanks.
Thanks.
Thanks.
