Hey guys,
I actually do a lot of work with VMware as part of my job, but my experience is limited to IBM/HP blades.
Currently I run a unraid server at home for my multimedia needs, which is working just fine but the mobo is a bit older doesn't have adequate PCIe lanes to support my new IBM M1050 cards. For now I can run one of them with 8 drives at full speed and an older LSI card with 4 drives at x4. This will work just fine in the immediate term. In the longer term, I've always wanted to build an ESXi whitebox so why the hell not now? Currently, the only hardware I have are the m1015s, Corsair 850pro PSU and a 640GB FIO ioDrive Duo.
Just after a bit of browsing, I think the GA-990FXA-UD7 paired with a FX CPU might be pretty slick. It'll give me (4) PCIe x8 and (2) PCIe x4 slots for HBAs, NICs, FusionIO and has IOMMU support in the BIOS. Direct-path is very important for presenting the HBAs directly to unraid.
I know AMD isn't exactly a player anymore in terms of raw performance, but I'm not really going to be pushing any intense workloads.
Any thoughts or suggestions?
