Red Squirrel
- Nov 29, 2009
Right now my server "room" is basically the basement as there is not much partitions other than the laundry/furnace room.
I plan to enclose and insulate the server room in order to make it cleaner, less dust, and less noise. For cooling I want to take a hot/cold isle approach where I will seal off the front and back of the rack as well as fill in the unused space. There will be a door of sorts to get to the other side, or perhaps just a wall and have two doors for the server room.
I have two ideas for cooling, first one is this:
Have an air duct with 6" pipe and a 6" inline fan to suck air from the hot isle, pass it through a radiator and then back into the cold isle. The radiator would have water pumped through it and then that water would be piped though my floors, like it would in a floor heating system. The final part of the loop would go to the crawlspace under my garage which is fairly cold. Used to get frost in it before I got it insulated. But it's still fairly dead air with no heat going to it.
The second idea, probably simpler to implement:
Have the 6" duct directly from the crawlspace under the garage into the cold isle. An exhaust vent with fan on the hot isle would exhaust the air into the furnace return duct or other area causing air to get sucked through that vent.
The air vent going into the cold isle would also have a furnace filter in order to try to keep the room as dust free as possible.
Also is it more effective to have positive air pressure or negative? ex: should I be pumping air into the cold isle or sucking air out of the hot isle?
I know I could just put AC but that cost much more money to run, and I rather make use of the heat generated by having it go in living space, instead of wasting it. If ever I get central AC, that would compensate in the summer.
Right now I'm using under 400w but I'd like whatever system I go with to support more if needed.
