My computer is a bit outdated (quite a bit. I built it about 3 years ago), and I'm having some difficulties figuring out exactly what is causing it to randomly restart.
I've tried swapping out the hard drives and the power supply, with no luck.
I let it sit for about 2 months, and had another go at it. I turned it on, and it lasted two weeks before it began the restarting randomly bit again.
It could be a software issue, but sometimes it will restart during the first few seconds of the boot phase in rapid succession, which leads me to believe it is a hardware issue.
If anyone has any ideas on what the issue could be, I'd appreciate your input.
I don't know where to start at as far as posting build info, so if you need any makes and versions of the hardware I have let me know.
Thanks.
edit:
I'm in the process of slapping on some fresh thermal paste right now... (I just realized that I hadn't tried this yet), but if anyone has any other thoughts on it, it's entirely possible that that isn't the issue.
I'll post results when I can.
Thanks.
edit:
