This will have been the third PC I have built, but when I'm not in the market for parts I tend not to read up on anything - hence this thread. However, I am not totally in the dark. This new pc will be use for internet/ light-medium gaming/general purpose stuff. Example of games I am looking forward to playing are Crysis, Assassins Creed, StarCraft 2, Mirrors Edge, Far Cry2, or whatever else peeks my interest. I'd like it to be quick in anything I do though, not simply games. I'd also like this computer to be quiet. My last 2 builds were noisy. This will have much to do with the GPU and case I believe. I'd like to budget around 800-900 dollars, but there is room to move around. Lower is always better.
Here is my most of my current setup:
AMD XP 3500+
1gig of PC3200 Corsair TwinXl
Gigabyte K8SN Ultra
X800xl AGP
2 Maxtor IDE hard drives
1 WD Sata hard drive
That Gamer sound blaster audio card
Samsung 204B LCD 1600x1200 max res
Here is what I plan to get:
I don't wonder into the realm of overclocking other then what RivaTuner can do so OC'ing isn't that big of a deal. However, I plan to pick up an E8500 - I hear they can OC decent on air alone. E8400 might be the way to go if the OC'ing potential is the same.
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115036
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814102795
HD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822148262
I plan to keep my 3 old hard drives and install windows on a new HD. Is this one decent?
Motherboard: This is where I am uncertain what to get. I don't plan on going SLI or Crossfire so one PCIe 2.0 slot is plenty. Is ddr3 worth it? Will the video card eat up a PCIe slot i may need?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128345
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131295
RAM: again, not sure which. Is 1066 much faster then 1000? The DDR 800's on newegg have lots and lots of good ratings.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227298
PSU: I was going to use my old PSU, but I might get a new one for the sake of being new and to handle a 4870.
CASE: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119138
I want this because I like the look and is relatively quiet. However, the price is absurd. Cases have always been tough for me because I want to like the look of the case as well as it being quiet, reasonably priced, and having some USB 2.0, etc connections on top. To save money this will be the thing I will flake on in order to get better components and stay within my budget.
OS: I plan to get Vista, which version I don't know. I can get them cheap through my school.
I don't actually plan on buying any of these components for a few weeks. I like to plan ahead.
AMD XP 3500+
Gigabyte K8SN Ultra
X800xl AGP
