Picking out a motherboard
tommy13
I'm going to start building my comp this Friday and I am stuck on which motherboard to get. The computer components are:
E7200
G.Skill DDR2-1000
Corsair VX550
ATi 4850
Sunbeam Freezing Storm
Seagate 250GB
Xigmatek HDT-S1283 or Arctic Freezer 7 Pro
For a motherboard I was thinking the Gigabyte GA-P31-S3G. I read somewhere that it was a good overclocker for the price. It's only $70. This is obviously a budget build so if anyone could pick out something not terribly expensive that would be awesome. Also, feel free to comment on the rest of my build if you feel something should be changed. All comments are much appreciated. Thanks!
The GA-P31-S3G is actually $65.
Anyway, don't expect anything higher than a 3.2Ghz OC with that motherboard. But it's a decent budget choice. Though, for me, the two RAM slots are a deal breaker. I like having additional slots for more RAM. Make sure that you cool the northbridge AKA memory controller hub (MCH) with a small fan or something.
I recommend getting this hard drive instead for two reasons: 1) It's bigger than the drive you chose, 2) It'll be about the same cost, and 3) you may get the single platter version which has been shown to be just as fast as Raptor drive:
Western Digital WD3200AAKS 320GB 7200RPM SATA 3.0Gb/s Hard Drive - $62
HSF wise, I recommend the Xigmatek. It's one of the best bang for your buck HSF out there now.
I agree Danny on the hard drive recomendation, but it will be intresting to see how samsung implements their new 330GB platters. They could very well come up with a compeditor to everyones favourite 640 and 320GB drives. But yeah, the 320GB is significantly faster than that 250gig, go with the 320GB.
As for the motherboard, If I had to peep up about overclocking I'd say go with DFI, and as such I recomend the CM64-AL... yessir... cant get enough of em ISA slots... :p
/sarcasm... why the hell is newegg still listing a motherboard thats four...five...six.... years old?! Good old newegg housekeeping.
anyways I wouldn't mind a recomendation here as I've got a guy with $600 looking for a gaming machine and something that will overclock for a damn, squeezing a couple pennies out of the motherboard would be nice. What do you think I should do danny, go with the DFI DK P35 (or P45 if its out by then)? Or is there a cheaper solution that will go just as far?
Thanks, I'll be sure to get the hard drive. I want to overclock a little higher than 3.2 though. Can you recommend a better mobo, maybe around $100.
@ MrWizard6600 and tommy13
I recommend this motherboard to both of you:
Gigabyte GA-EP43-DS3L Intel P43 Motherboard - $95
It should OC pretty well. It's limit is around a 400FSB so you could theoretically hit 3.0ghz with the E7200. But I recommend sticking a small fan on the northbridge just in case.
Though, MrWizard6600, if a DFI P45 motherboard comes out by the time your friend buys his PC, take a serious look at it if your friend wants to squeeze every ounce of performance out his system.
The DS3L's limit is 400Mhz? Or is that just without additional NB cooling? Did I miss something? :p
