Photoshop/Light Gaming
Photoshop CS4 - Illustrator CS4 - Corel Draw - Light Gaming ( TF2,Minecraft-RPG games) HD Movies
$800 but can go up to $1000 if there's better performance.
3) Where do you live?
California
CPU-CPU Cooler-HD-Motherboard-RAM-Optical Drive-Case-PSU-Video Card-Gaming Mouse
Keyboard-Speakers-Monitor
6) Will you be overclocking?
Yes
17"- I'll be acquiring a 24" in 3 weeks.
In 1 week.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
USB 3.0 if possible - Crossfire/SLI for future upgrades.
No, need Win 7 64bit
Any plans on upgrading to Adobe CS5? If so, when?
Do you use those programs as a primary means of income or is it more just for fun, on the side, a hobby, etc.?
This build assumes you're not upgrading to CS5.
$340 (before $10 MIR) - Intel Core i5 2500k and MSI P67A-G43
$155 (before $15 MIR) - SAPPHIRE Radeon HD 6850 (use promo code EMCKFKB25)
$130 - Samsung F3 1TB and Antec EarthWatts EA-650 650W PSU
$40 - G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333
$35 - Cooler Master Hyper 212+
$60 (before $10 MIR) - Cooler Master HAF 912
$19 - Samsung DVD Burner (use promo code EMCKFKC38 for free shipping)
$100 - Windows 7 Home Premium 64-bit OEM
$53 (before $20 MIR) - Logitech G500 (use promo code EMCKFKC49)
I have to run to lunch, but I'll update this later because I think I can get this budget down. The thing that's causing the budget to be high is overclocking, hd movies, and the mouse.
Are you encoding/editing HD movies, or just watching them? You can always do a reg edit to enable CUDA acceleration for the Mercury playback engine, as well as some plugins that will benefit from CUDA. Otherwise, an AMD card will be fine if you don't plan on upgrading to CS5 anytime in the near future.
I agree. Knowing if you're planning to upgrade to CS5 is very important for how this build gets laid out. I also think it's important to know if this is for work or play, because I really think a quad core Sandy Bridge is the way to go, but I don't think I can get it down to 800 without cutting corners. Lulu and I have both posted builds in this other thread that also focuses on CS4/CS5, but has a higher budget. You might get a few ideas from there that will help you out as well because some of the parts (SSD, high end graphics card) can get trimmed down or out pretty easily.
I'm not planing on upgrading to CS5 anytime soon. I primarily use my system for freelance work and it's not my primary means of income, I also don't encode or edit HD movies, I would only like to watch them.
EDIT: I'll be back later today, to answer any other questions you guys might have. I'll review the builds you guys posted up. Thank you
Oh, okay. I'd still encourage you to find a way to make Sandy Bridge work, but if sticking to the $800 end of the budget is important, you can definitely get there by using an AMD quad core chip while leaving yourself room to upgrade to an AM3+ chip later.
Alright, I decided to go with:
Core i5 2500k
MSI P67A-G43
HAF 912
8GB of G.Skill RAM
Samsung DVD Burner(Tonytnnt & luluthemonk suggested)
Samsung F3 1 TB HD(Tonytnnt & luluthemonk suggested)
Antec EarthWatts EA-650 - Bundled with the Samsung F3(Tonytnnt)
All I need is the video card, do you guys think the 6950 is too much?
