Photoshop Elements Machine
Dataman
Any improvements I can make? I want Quiet System that is fast in Photoshop Elements and maby CS3/4.
Sonita III with 500W PS - $45 (got over Christmas)
LG 20x DVD Sata - $22
WD 640HD Black $160 (2 of them)
MSI DKA790GX AM2+ $125
Logitech 100 Kb/M $25
SABRENT CRW-UINB $15 (Does SDHC)
Adata 2g Memory DDR2800 $92 (8g Total)
AMD Phenom II 940 $229 (15 bucks off total used also)
MS Vista 64 Prem $99
Nero 9 Mini $45
Zalman CNPS9700 $54
1. Can I get Sata DVD with Nero Bundled? Not Nero 7, but Ver 8 or 9?
2. Any better MB? has to work with CPU enough to flash!
3. I assume CPU has HS/Fan? Do I need aftermarket? Anything easy to put on that does better job. Ie Quiet.
No OC will be done on this System. No Games, going to use DVI Onboard MB.
It's going to do IE, Word, Photoshop Elements.
DM
Please answer the questions in the sticky marked "ANSWER THESE QUESTIONS FIRST" So that we can help you better
1) Dunno. Haven't looked for nor used Nero in the last 4 years.
2) Answer the stickied questions and I can answer this question
3) The CPU already comes with a HSF. Besides ditch the Zalman since there are significantly better HSF out there for the money. But again, need you to answer the stickied questions before I can recommend parts.
