phinix
- Dec 13, 2005
Thanks Bill, had "a few" days break, but I'm back!
UPDATE
As you all can see I'm not dead
I was working on something on the side and didn't have time to play with my Aurora. This weekend I had few moments so wanted to do something that will show some colors of my project.
As I showed and did last time I was outside, enjoying good weather (in last few weeks it has been cold and snowing here in Glasgow) I had cut out some rectangles from aluminum. There were going to be support plates for LEDs under drive cage shelves.
So I decided to cut them in half, they were bit too big. Then I drilled holes in them - I wanted to mount them under shelves by screwing them to it.
I marked holes on them...
..then drilled and then matched those holes on acrylic shelves...
Then I drilled holes in acrylic and pushed those brass inserts into the holes.
You can see the pattern there - two 5cm LED strips go in the aluminum plate, then turn over and screw it to the acrylic shelf.
And here's the sandwich
LEDs will be soldered together later.
Now, I had these pieces cut from blue acrylic.
Those are the bits for "drive envelopes" Yes, everything need to have unique names
I needed two 7mm deep/tall envelopes for SSDs and one 9.5mm tall for 2.5" HDD.
Now, those two pieces with lots of holes are for ATX and PCIe cables, I will get back to those later
Big blue piece on goes on white first...
Two small pieces go on each side... small squares will keep drives in place.
Top piece goes on top
Here is a little mock-up of the envelope.
Next two photos is just me playing with colors
I was taking all pieces for a bath.. Time to do some wet sanding on all edges before I start gluing them together...
First gluing long bit... and rest of them, one after another...
Boom.. first envelope ready...
..and glued to the big white piece...
Few good minutes later.. all three shelves ready to go!
Maybe edges don't look perfect, but they're really ok.
I noticed my special acrylic glue become solid for some reason (was waiting in the box for 2 years, so maybe time did its job...). So I had to use super glue, which leaves a bit of bright stains under acrylic bits. But at the end it all looks good I say...
It was time to try out the taller one with some spare HDD...
Fits nicely... good job.. Looks ok. Happy days...:thumb:
That is all for now. Next time I will prepare radiator cage. Time to screw down the big boy and build it up with nice mesh.
Till next time:thumb:
UPDATE
