phinix
- Dec 13, 2005
Aurora - (plural: aurorae or auroras) is a natural light display in the sky particularly in the high latitude (Arctic and Antarctic) regions, caused by the collision of energetic charged particles with atoms in the high altitude atmosphere (thermosphere). The charged particles originate in the magnetosphere and solar wind and, on Earth, are directed by the Earth's magnetic field into the atmosphere.
Hello everyone and welcome to my new project log!
This time I would like to show you something different. It wont be a scratch build, like all my previous projects. This time Im going to mod a case!
I hope you liked my Cube and Nano Tower and now Im hoping you are going to like what Im about to start. So lets see whats brewing shall we?
PHINIX AURORA
It will be a case mod, based on Lian Li A04, a micro ATX case. Reason I picked this case is that it is one of the smallest mATX cases on market it doesnt have any particular feature that I was after. It is simple and easy to mod - this is why you can do basically anything with it
I havent done any case mods before, so it is going to be a challenge for me, but also a good fun.
I have some ideas what Im going to do to this little case and would like to share them with you guys... again!
Main ideas:
Color scheme: white and blue, pure aurora
Shape and size: very close to the size of the case itself:
(W) 188mm x (H) 386mm x (D) 460mm
White powder coating and painting
Blue and white acrylic elements
Customised side panels and front panel
Watercooled CPU and GPU
Internal power chamber including PSU and all wires and power junction
Custom made drive cage
Custom Interior lighting
Hardware (may change during the project):
i5 2500K OCed to the limits
mATX motherboard
8GB of RAM
GTX580 graphics card
modular PSU
2x SSD and 2.5 HDD for storage
Watercooling:
CPU block/pump
GPU block
Double radiator
Reservoir
Blue tubing
Compression fittings
Temperature sensor + lcd display
Blue coolant
First phase has started - I'm gathering all hardware and items. It will take a while, but couldn't keep this project hidden any much longer:blush:
So again... JOIN ME IN THIS NEW CRAZY MODDING RIDE !!! ::rock:
My Phinix Aurora Project is sponsored by:
MAYHEMS
Mayhems kindly supported me with the following items:
- Mayhems MHE240 LE Quad pass double radiator
- 2x X1 - UV Blue Coolant
- Blue 10ml Dye
- UV Clear/Blue 10ml Dye
COOLER MASTER
Cooler Master kindly supported me with the following items:
ENERMAX
Enermax kindly supported me with the following items:
MNPCTECH
Well known to all of us, professional modder Bill from MNPCTECH kindly supported my project again, by sending me these items:
- Mnpctech Machined Aluminum "Diamond Knurl" PC Case Feet
- Mnpctech Machined Billet Aluminum Fan Grill Blow Hole Kit 120mm
- 16x Blue Anodized Case Thumbscrews
- 80mm Chrome Acrylic HC Fan Grill
- PC Mod Digital Thermometer
HINDLEYS
Hindleys is a huge design and technology supplies shop, where you can buy all the kind of materials, tools, electronics, hardware and consumables and all the craft and design products.
They kindly supported me with the following items:
GIGABYTE
GIGABYTE kindly supported my Aurora project with their Z77 mATX motherboard - GA-Z77M-D3H.
EKWB
EKWB kindly supported my project with their nickel/acetal water block for GTX670 with a nice backplate.
SCYTHE
Scythe kindly supported my project with their newly announced Scythe Kaze Station II fan controller!
MONSOON COOLING
Monsoon Cooling kindly supported my project with their compression fittings and adapters.
- 3 kits of white compression fittings
- 2 white 45 degree adapters
- 6 white 90 degree adapters
CHILLEDPC
Tom From ChilledPC is helping me out with his CNC cutting and powder coating services.
I've been using Tom's services since 2008 - always pleasure working with him.
