ritterbutzke
- Dec 15, 2014
@flossy_cake
How about you at least read the review before "dropping knowledge".
At 100% brightness a constant voltage is applied to the backlight as you would expect. As you reduce the brightness setting a Pulse Width Modulation technique is used for backlight dimming. This operates at a low and fixed 240Hz throughout the brightness adjustment range, and the duty cycle (on time) is just reduced as you lower the brightness setting.
