sirmonkey1985 was folding on his Phenom II 940 during the Chimp Challenge. With two Linux VMs and his CPU running at 3.5GHz, he was getting around 2800-2900PPD per client if I recall correctly.
From the sound of things, the Phenom II gets about the same PPD as a Kentsfield Core2Quad at similar clock speeds.
hmm...my C2Q Q6600 is oc'd to 2.7ghz and it does about 4500ppd, that is with 2 notfred vm's
I doubt it would make any difference. F@H is limited by computation speed, not communication bandwidth, since the actual data traffic is very small.probably.. id like to see some one run the notfred client with a 940 @ 3.5ghz with a board that correctly supports a 940.. since im only running at 1.6ghz(3.2ghz) HT.. stock for the 940 is 1.8ghz(3.6ghz) HT and can easily be overclocked up to 2ghz(4ghz) HT..
per VM or combined?
my numbers are per VM so combined it would be 5800-6000
Your output is probably because of the clock speed your CPU is running at. If you overclocked more, you would probably see a big difference in points output.that was combined...
My 720 with a single VM gets about 2910 ppd at 3.5 Ghz. It completes 1% of a 1920 pointer ever 9:30. It runs about 49 degrees Celcius while also supporting a HD4890 folding. I just need some more video cards to finish loading that 3rd core.
