- Aug 15, 2005
Sometimes AIO's can keep phase change material from melting properly, causing abnormal temp behavior.PTM7950 was amazing on my 4090 gaming laptop with 13980HX. From overheating CPU to about 75c during max use in Cinebench. It worked really well with the GPU as well.
However I'm not very impressed with it on my 7950x3d. I'm having 47-48c idle and it goes up to thermal limit (85c) when running Cinebench with a 360 AIO. I'm not sure if it's the cooler or something else, but definitely not impressed.
It can also take a few thermal cycles to achieve its peak performance. If you've only just put it on and are still in your first evening of testing, wait a couple of days and use the PC. Then do another round of testing and compare.
Also, it doesn't give huge benefits on a CPU with an IHS, like it does on bare GPU and laptop chips. Overall, temps will be similar to a good paste.
although it won't dry out or pump out over time. And personally, I have noticed smaller differences in temps between cores.
