Nehemz
- Apr 10, 2017
EDIT: The Phanteks page for this case is UP at http://www.phanteks.com/Enthoo-Evolv-mATX-TemperedGlass.html
There's a new Enthoo Evolv thats gonna be released on this month. A certain someone in the Phanteks forum said that he emailed Phanteks about the case.
For those who are wondering, Its the first case that Dmitri showed when he went to the CES Phanteks booth, along with the Project 217.
And its a far better version of the original Enthoo Evolv mATX.
They moved the usb and audio from the side to the top part of the case with its own cover, like the one that the ATX version has.
They also got rid of the metal plate that is attached on the sides meant for small water cooling reservoir and pump or SSDs that made the original Enthoo Evolv mATX have a smaller side window, which made it the ugliest among its series. You can see it in Hardware Canucks video that the case is lacking the screws for it on the sides inside the case.
Also, Black Film on the Side Panel to hide your messy cables.
And RGB comes along with it!!!
Top cover is screwed in, so you can grab the top to carry it around. The original isnt screwed in so it will fall off when you grab it by the top.
