Kaspersky just mentioned its not a variant of Petya but something new. 2k infections so far, mostly in russia/ukraine.
Edit: Link:
hahaha, Kaspersky has named it NotPetya, lol.
Because most of us purchased a legitimate copy of Windows.
I'm no fan of the NSAs part in this, but AFAICT, this is a case of negligence by IT or management. there's just no excuse for not applying patches that are almost 4 months old. People who don't apply patches are like parents who don't vaccinate their kids.
And all so people can use the world's least compatible office suite.
I don't have any .dll file on my computer, how do I protect myself now?![]()
Fucking littlefinger!!!
I would love to see the testing behind this claim.
i don't need to Heatlesssun, and you know this as we've been over it before. Standards, remember?
Yes and Office 2013+ supports both non-strict and strict OpenXML as well as OpenDoc. What you often confuse with file standards are actually product features that sometimes don't translate across applications. File standards DON'T dictate features.
Yeah, nice brain fade.![]()
So where are all of these non-standard documents that don't open in LibreOffice because of issues with compliance with file standards? I've had exactly this same argument with someone here a month ago. He pointed to Excel spreadsheet that deal with WoW that he swore didn't open MS Office but would in LibreOffice and it opened fine in MS Office. Indeed the formatting was significantly cleaner. The formulas however seemed to work correctly in both.
Really, it's simple. All one has to do is point to specfic XML code that say "Ah hah! It doesn't work because Microsoft broke the standards!" Those standards documents for OpenDoc and OpenXML are huge and complex, particularly OpenXML.
Office does not comply with certain ISO standards
Again just which ones? https://msdn.microsoft.com/en-us/library/gg134034.aspx. You keep say over and over the same thing without specific references to the problem. The only thing you've ever specifically mentioned is OpenXML strict and non-strict versions and Office 2013+ supports both. And also the latest version of ODF.
This is not the place, we've been over it before. You've really gotta start paying attention.
And you gotta stop making extraordinary claims about how Office handles thousands of pages of complex documented standards without evidence. Yes you've said the same thing over and over without any evidence, just a complaint about strict vs non-strict OpenXML with are both supported in Office 2013+.
Would you 2 get a room, I'm buying.i don't need to Heatlesssun, and you know this as we've been over it before. Standards, remember?
Where compatibility issues do not exist between any other office suite, yet they exist with MS Office using open ISO standards - Than no matter what Microsoft try to claim from 2013 onwards regarding the strict standard, obviously logic dictates that it all has to be bullshit: As the purpose of standards is to remove the possibility of compatibility issues.
LOL! It's just that it's not difficult for him to make his case by just pointing to specific XML generated and showing the compliance problem. That's one of the points of the standard by which every developer uses to read OpenXML files. You can point to it and specific XML and say "Hey, that's not standard."
Yes and Office 2013+ supports both non-strict and strict OpenXML as well as OpenDoc. What you often confuse with file standards interoperability are actually product features that sometimes don't translate across applications. File standards AREN'T features.
It's pitiful how you try to rationalize their doings.
I've asked repeatedly "Where exactly are standards being broken?" Where I have found references to complaints there's never any sample documents. This isn't a matter of rationalization, I'm just asking what exactly the issues are? And even if the formats were in total compliance by Microsoft, that still doesn't mean that features and implementations would be standard.
As long as the MS Office documents are not compatible with the free alternatives on the market (which are cross compatible) then MS intentionally broke compatibility. No need for sample documents. We've all seen how even different versions of Office won't play ball together. It's all intentional to force consumers to upgrade and pay.
Sorry, but I don't follow. Are you saying you have software that's unable to work on patched systems?So if you work in a development lab and you are still supporting older versions of your product, you know, for older OS's that are still not End Of Life yet, or not too far past their EOL date. What do you do when your software is too "old" for the patches?
Now in our labs it's less of a deal cause we keep the labs cut off from the world but not all dev labs do that. I do agree with you as a rule. But there really are some exceptions.
No .dlls you say, what weird version of Windows do you have son ? You need to get you one of them there Windows 10 programs on your PC. I hear it is installed as a suppository these days.
Yes, but is it really relevant if it's a system that's never exposed to the outside world? Seems like it'd be pretty much impossible for this attack to affect these machines.nilepez, the short answer is yes. The longer answer involves explaining that many many computers are running in environments which never ever see the internet and exist within enclosed ecosystems, controlled, and sterile. The reason is because some specific applications are developed at a slower pace, the rest of the world moves too fast and frankly, they have a reduced need to keep up because they don't depend on it.
An example, say I have a special system used to collect, analyze, and data base biometric data. None of these systems connect to the internet, ever. I only have to make things work, and I only need to improve on functionality and performance while making adjustments on the user interface aspect of the software. The only time I have to innovate and "catch up" is when hardware developments that promise significant performance benefits demand changes in software. Then I have to set out to play catch up and incorporate patches for those elements of this enclosed system that we use. If my system doesn't require Flash Player, I have no need of patching my software to keep up with it, etc.
Furthermore, I may have specific customers who are still using older hardware and are still using the older operating systems and software to match. I would also have to maintain this software even though the rest of the world has left it in the dust.
Is it clearer now?
