PeRs-pLeXeD!
Defyant
I'm doin it again!!
This is just a quicky weekender mod :D while i toy with ideas for HPR3 :)
ive had a ton of old green plex laying around for a while... and always had the idea to do oOoOZ type case theme.
the orig idea was to do this mod on a standard metal case, but since i had a EX shop display Clear case laying around i thought why not!
I also had 5 x Green UV 120 and 80mm fans that were donated buy X-Com a while back so it would be great to finally put these to good use!
A custom made Defyant style mega res was also sitting on the shelf with no home...the green theme of this res would also be perfect !
This Case PeRs-pLeXeD ! will be first of a 3 in this series of qik weekender mods.
The seconed Will Be "Flamed" and the third will be "Shocked" and both of these will done in a similar method using orange flames and blue/purple bolts of lightening.
anyways heres how it started yesterday.......
Sitting @ the end of the bench.... simply throwing on the res and 2 fans! the mod was half done :p
I thought id set it up for a couple of proper shots to get a better feel for the mod.
UV was going to be an imprtant light source for this mod and testing with a single light i could see that this was indeed goin to look pretty cool.
Defyant
The next part and main feature of this mod will be creating the "oOoZ" from UV green plex.
A very simple pattern is marked out on 3.5mm green plex cut!
Using a spare case the oOoZ is bent over the edge! this will give the effect its running down the side of the case!
For the mother board side of the case, a simple sPLat is made
and to add to its effect some smaller spray drops are cut sanded and added
To keep the theme going inside the same is reapeated on the floor and a "sPLaT" will be added as a "sortof" motherboard cover!
Defyant
Some more work is done to the Top oOoz and a top fan duct is cut with some smaller themed type holes.
its placed back on for to make sure allstill fits well :)
and a qick test with some UV
The front of the case will need to be cut to allow the fitting of 2 x 120mm UV coolermasters, which will supply air to a dual 120 rad for the watercooling.
A section is cut of of the original front panel and a new support bracket is made for the dual 120's
A rear Green back panel is added for contrast.
The edge of the new front facia support is routed smooth as is the inner holes for a cleaner look
Next is to frill countersunk type holes for the fan support bolts.
Steinless M5 Hex Head bolts are used
Next is "Fire" polish the edges all nice and clear again .
Assembled with the fans and bolts.
Defyant
DAY 2
Got a late start today :( but as promised i was still keen to knock this mod over in a weekend.
first thing to start the day off with was some painting :) i decided that i didn't want to "flood" the inside with green! so to keep the inside of the case uniform ive gone with matt black.
The psu, water blocks , pump and Cdrom are prepped and painted. The CPU loom is covered using black flex cover... again..not wanting this to be a "feature" black is best used here as well.
This will allow the internal Green cover and water tubes to become the main internal features.
The first mod of the day after painting was to Relocate the power/reset and activity leds. Due to the adding of the Dual 120's, the original area where these were was cut away.
I little but of carefull drilling and tapping now has the buttons/leds replaced over to the side of the case.
Next was to design a motherboard cover! YES! the good old motherboard cover :p like my tanks these are becomming a bit of a trade mark...but i got to have a bit of fun with this one and a less techinical but well themed cover was on the cards.
To attach the cover holes are drilled in the far corners. To give some flexability gromets are added
A long scew with a perspex 22mm spacer isused to suspend the cover above the motherboard.
The cover is then bolted in using the old board locating risers.
Defyant
Time to add the previously painted and cabled PSU, i also decided to add some UV green molex ends i'd had left over from an old mod.
Next was time to add the water blocks.This is an old Jarron Water block ive had laying around for while...a custom 10mm plex plate bracket was fab'd up and used for this mod.
A Swiftech GPU block is used to take care of GPU cooling
2 hose holes are added to the rear for the external res hoses to pass thru.
The Swiftech MPC600 pump is bolted in
all hoses are connected
The system is filled with the usual suspects!
Pump is run for a while to bleed the system and the res is snapped back onto the top of the case
Internals are wired up and checked
Defyant
Time to fire it up , stand back and take a few shots! :)
Time to switch some lights off
With some UV lighting!!!
Well i got it done in a weekend! altho i didn't rush the case...i still feel theres a few things i'd like to change.
Cheers guys.
(7\)
very very nice.. i'm a sucker for clear cases... can i ask where you got the res from?
WOW! thats an awesome mod. i cant wait to see stages 2 and 3. i cant believe this was done in 1 weekend. GREAT MOD!
Pkirk618
yeah, they seem to be making a come back--of you can say they ever left. Many ideas coming to life with new technology and material.
Nice work. Green, especially goob green is cool!! :D
xrdotimcr
Congrat's on HPRES2's apperance in PC Modder. It was a bad picture though.This was also a nice mod. Would've looked better on a case made of black plexi, but that's just my opinon.
xrdotimcr
banGerprawN
Man...I just lost my load. That's so frikkin' awesome!
Love the res. Nice job on the Atomic tube. From Oz?
guzmanistan
doooood thats crazy. everything's great except one thing...and its small. get rid of those splitloom cables and sleeve that shiot
Defyant
thanx heeeps guys :)
there are still a few things i'd like to change but need to get on with other mods for now :)
The custom res's i make myself..thats a new design i came up with a while back.
Theres also the
The "Stubby" ,The "Fatboi"
The "Sumo".
The "Mini's",
The "Duals" and of course!
The "MEGA"
All part of the "Defyant range of plex custom Res's :)
Defyant
xrdotimcr
Cheers mate...thats what happens when you say to a editor...heres a bunch of pics take your pic :(
its all a learning process...but im happy and honored to be there :)
cheers , sure am :)
xrdotimcr
I'm going to submit my project when I finish it. You can check out the worklog so far here. And once again, good job. Did you get anything for being put in the mag? I know for MaximumPC you get a $1500 dollar Newegg.com gift certificate.
amalgamas
without reading who started this thread and not looking at the original poster, i knew this was a defyant case just by the look of the res. good work as always.
Defyant
UPDATE!
I wasn't happy with the front cdrom cover door thingy.... just looked like a foot to me...
And i didn't bother to incorp an eject button.
Had a bit of time to think about it @ work today and came up with this new door and idea for an eject button.
some one had also mentioned the PCB for the buttons looks a bit outaplace thru the plex.
A bit of black fixed this :)
the design for the new door~! this time i went for a "sPLAT" rather than a gOoP!
the idea this time is to attach the Green plex splat to a clear door panel which is already attached to the cdrom door.
The Custom Eject button will be a "sliding cylinder" type construction and will consist of a shaped inner shaft that runs thru a hollow shaft with the button glued to the front.
the whole assembly is then attached to the clear door panel.
lost?
the 2 main parts to the mod. an outer clear tube with a solid tube that runs inside.
the inner tube is sightly larger then the inner diamater of the inner hole. this is a good thing because it will give me a rear stopper(foot) @ the back.
Over to the bench press to take a few thou off the inner shaft.
pretty crude! but it works
A qick fine sand
Defyant
You can see how the innner shaft now has a stopper @ the rear this will press up against the eject button on the cdrom.
a sexy little green button is cut!! my god this was like micro surgery!!
To take the sharpness off the button some heat is applied!
it now looks more like alil green boiled lolly!! :)
The clear front panel is marked and a hole is drilled for the outer cylinder.
Good old plex glue will fuse bond this together forever!
a qik test! all is good.
Next is to glue on the button
Defyant
The whole unit is attached back to the CDROM.
the front splatt theme cover is glued on
and finally! a finger test!! :) i love it when things just work!
Well since i was modding along now!....... i thought that i would glue on the side splatt.
Defyant
just little things! that were "erking" me... theres still a few things to do...i need to get a new side panel cut. orig was lost.
and im keen to add a green LCD to the front as well.
But i think you will agree its lookin better with each bit of etra work :)
compslckr
damn, you have amazing plexi skillz :)
that is an awesome mod.
i tried cutting a piece of plexi in half once and i shattered both sides :(
keep up the awesome work!!!
Ozone77
Great plexi work!
Any guides we should read to get some of your skills? I could definitelly use some pointers. Where did you get the plexi glue/welder? The Home Depo / Lowes people I asked were clueles. I tried silicone, which is transparent, but it is very flimsy.
Oh, and you said you have some work left, does that include changing the wire loom? I'm just like 'ugh.' I personally think some wire mesh would look nicer, although it is more work to install it.
banGerprawN
Fuck that's just plain sexy. I'll trade you...my quite-hot-but-useless-in-the-kitchen girlfriend for that fine piece o' ass :eek:
Killermac
Wow that is great, it sparks me wanting to go and pickup some green plexi. Again very nicely done. I really love the blue green glow of the whole unit. :eek:
KM
Egrimm
Great job, you have impressive plexi-skills. You just inspired me on new ways to use plex and getting the parts to finish off watercooling my pc (again).
Elios
man thats a great mod and i dont even like clear cases and i think it look awsome :D
skudmunky
You better hope she doesn't see that post. :D
Anyways, freeking good mod man. this is one of the only plexi cases I actually like.
poopypants
man u r a machine, between here and bit-tech, i've got a full time job just watching you mod :)
revenant
wow... really nice work!!! very creative!! I love the sub-panel which goes over the mobo (with a hole over the cpu) and around the video card... very cool!!
