I have the weirdest problem with my videocard.
Several days ago, I noticed that Oblivion was lagging slightly with AA enabled. I though it was just me imagining things. Today I tried playing The Witcher, and it also ran slower than I remembered. FSX was also struggling slightly at my standard settings.
So, to confirm I wasn't just seeing things, I ran 3DMark 06. Performance had indeed decreased - I used to get about 10k 3DMarks, now I was only getting 7k. Looking at the results in detail, CPU test perform about the same, but the performance in all the Game tests has dropped significantly, by between 25% and 50%. The HDR tests took a bigger hit than the first two game tests. So, it's not a CPU/RAM/Mobo problem, but a graphics problem.
I've tried uninstalling and reinstalling the driver.
I've only done two things the past week - I installed RivaTuner, and I installed a fanmate and plugged the GPU fan into it via the case_fan connector on the mobo instead of the GPU fan connector on the videocard - is it possible the videocard has underclocked itself because it can't sense the GPU fan?
I *think* there may be a problem with the GPU and VRAM clocks. I tried overclocking with Rivatuner som days ago, but it wouldn't detect the default clocks correctly. I've tried uninstalling Rivatuner but that didn't help. Also, the Gigabyte Gamer HUD (tweaking utility provided with my videocard) popped up a balloon tip saying that "Your videocard is overclocked, click here to restore settings". When I click the "Default" button in the HUD, it set all the clocks to 0 MHz and now it won't allow me to change them at all. 3DMark system info also shows:
Min GPU Memory Clock 0.0 Hz
Min GPU Core Clock 0.0 Hz
Max GPU Memory Clock 0.0 Hz
Max GPU Core Clock 0.0 Hz
Edit: I just installed Ntune and the Nvidia Monitor also shows 0 MHz for all clocks. In the Performance node of the Nvidia control panel, all the sliders are stuck at 0 MHz, and can't be moved.
In spite of the "0 MHz" speeds, performance is still the same - about 30% lower than it should be. Any ideas short of reformatting the harddrive? Is it possible the BIOS somehow got corrupted?
