NeonFlak
- Jun 11, 2004
I just received a Perc with BBU and 256mb cache.
My file server is running Vista Business 64bit. All pcs on my home network are Vista Business 64bit. I have the Perc setup with a single raid 5 array of 4x 750gb Samsung F1. Flash to LSI v61 firmware, using the latest Vista 64bit drivers from LSI. Array is setup as a GPT in vista as it is over 2tb, but still as a basic disk type.
Stripe size is 128kb
Read - adaptive
Write - back
I/O - direct
disk cache policy - unchanged (default option)
I have tried various different settings, MSM shows everything is operational. The problem, I have all my pcs download everything directly to their mapped drive which is the raid 5 array. Everything downloaded to the raid 5 array from a network pc is corrupt. Doing downloads on the file server itself doesn't work either. I also have remote differential compression turned off on every pc just for shits and giggles.
None of my pcs will start with only one stick of ram, and I don't have another 256mb stick to test with. So I am not sure if the ram is bad. Just looking for some suggestions?
Thanks
Read - adaptive
Write - back
I/O - direct
Thanks
