Skylinestar
- Jun 14, 2011
I'm upgrading from intel Pentium G3240 (53W TDP) to i5 4570 (84W TDP), yet maintaining that same thin intel Pentium stock cooler (no copper core). Should I be worried about heat dissipation? Tuniq TX2 thermal paste applied is pea sized. When idling, HWiNFO64 shows CPU package 48°c, motherboard 38°c, HDD 35°c, GPU 39°c. Load is about 90°c. My room is 28°c. Are the readings normal? I know the i5 stock cooler is the thin cooler but with copper core. Hence, I'm a bit worried.
Screenshot of OCCT stress test attached.
