Brackle
Old Timer
- Jun 19, 2003
The Titan Z is great for gaming + CUDA applications.
If you are just gaming get a 780ti SLI set up.
That the 295 needs water in order to run says a lot about how inefficient the chips are in it. Next gen they will need liquid nitrogen in order to compete.
Or you buy 2 Titan Blacks and save yourself $1000 and have faster gaming+cuda performance.
Which makes the Titan Z a waste.
And in case you want to bring up the fact that someone with an ITX would want it for a small gaming+cuda machine. Well that myth is busted since the Titan Z is 2.5 slots.
Then you might bring up the fact that then you could use a matx motherboard. Well that is busted since you could stick the 2 Titan blacks on the matx motherboard and save yourself $1000.
Then you might bring up that it uses less power. Sure you are right, 26w is alot of power saving.
